Switched wire under hood - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-21-2013, 09:17 AM
racecar67's Avatar
racecar67 racecar67 is offline
Vehicle: 2014 Ram
Rep:25
racecar67 is on a distinguished road
Question Switched wire under hood
Hey guys anyone no an easy to get to switched hot wire under the hood I can pigyback for the electric fan on my aftermarked oil cooler.
Thanks in advance
Mike .`.. , . .`..><((((>
Old 08-21-2013, 09:21 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
The TIPM is right there. You should be able to tap off one of the switched fuse links in it.
Old 08-21-2013, 10:12 AM
racecar67's Avatar
Vehicle: 2014 Ram
Rep:25
Not sure where that is.
Old 08-21-2013, 11:49 AM
Rep:2968
It's Mopar's fancy word for fuse box. It will be black and have a removable cover. I believe it will be on the drivers side on your truck beinst the air filter housing in on the passenger side. It holds all the fuses and relays for the truck. They make inserts that fit over a fuse, so you should be able to locate a switched fuse, remove it, put the tab on the fuse and reinstall the fuse. Add a ground and zip ping badda bing, you've got a switched circuit.
Old 08-21-2013, 12:16 PM
racecar67's Avatar
Vehicle: 2014 Ram
Rep:25
I can do that!
Thanks
