Old 08-21-2013, 12:37 PM
bigubomb's Avatar
bigubomb bigubomb is offline
Vehicle: 2001 Dodge Ram
bigubomb is on a distinguished road
Default 2000-2001 factory off road package
I have a 2001 5.2l 4x4 with the sports package. I have been looking at suspension lift and have noticed that a lot of the lifts are not available for 00-01 year models with the factory off road package. I have the original sticker from the dealer and it does not say anything about an off road package. The sport package came with the larger tires and looks taller Than other factory trucks. Curious if anybody has dealt with this and if there is a way to find out if my truck is equipped with this package.
Thanks
Old 08-21-2013, 12:47 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I didn't think that the Offroad Package could be had with the 318.
Easy ways to tell: On the tail gate, there is a decal that says "Offroad" in red letters under the 4x4 sticker. The front differential is trussed, or has reinforcement around it. The truck will have a 2" lift with 17x8 rims, 275/70/17 tires (33's), and 4.10 gears.
Pic of the tailgate:
EDIT: If the window sticker didn't say it came with the Offroad package, then you don't have it. Mine says it on the window sticker, and it was a $2k option.
Old 08-22-2013, 01:59 PM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:57
Wh1t3nukle will become famous soon enough
Less than 33" tire...like 32.2" for the conversion. Just splittin hairs there, however, you can go directly to a 33"x12.5x17 w/o issue on the ORE. Everything else Persuader shared is pretty spot on.
As far as lift, when looking at kits is to ignore the stipulation that "does not work with offroad package". BDS says that from what I remember.
The lift in the ORE is purely in the front springs. They give an additional 2" over a non-ORE 4x4 Ram. So, lift kits will be changing that spring out completely. Well, kits that are with springs as opposed to spacers. Spacers you put on top of the coil spring.
Example, 3" kit using coil springs will only net you a change of 1".
Take out 2" ORE coils and put in 3" kit coils.
Hope that answers the question.
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
