Old 08-21-2013, 03:47 PM
teryxrider teryxrider is offline
Vehicle: 2012 Ram 1500
Rep:13
teryxrider is on a distinguished road
K, just to clarify. You did pull up on the lever when lowering the trailer onto the ball right? Then when you have it sitting on the ball fully the lever still won't go down?
This is correct, the lever is up when I lower it onto the ball. At this point, the lever does not lock into place downwards. When the trailer arm is away from the ball, I can easily lift the lever up and down by pressing the trigger. When it is on the ball, it goes down partially but not enough to engage the locking mechanism and lock into place.
Old 08-21-2013, 04:06 PM
MTG8810's Avatar
MTG8810 MTG8810 is offline
Vehicle: 2005 Dodge Ram Daytona Quad4x4
Trim Level: Daytona
Color: Go ManGo
Rep:38
MTG8810 is on a distinguished road
Before you kill yourself, get the right size ball, connect the trailer to the truck, lock it down, drop the ramp, load the trailer, heavy end forward.
Good luck!
------->Remember, a Stranger is just a Friend you haven't met yet!
------->DAYTONA#03115 "AmbeRam"
Old 08-21-2013, 05:34 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
It sounds like you have the right ball. If you look up and under the area the ball locks into on the trailer you will see how the mechanisim works. There is kind of a semi circular piece that locks onto the ball. I've always found that pushing the trailer backwards helps the lock go down once you have the trailer hooked up to the ball. Yeah, I've been known to kick it down also.
Another hint drive the UTV onto the trailer until you see the back of your truck drop down some. You want some tongue weight. I think 10% is the rule with a bumper pull trailer.
Old 08-21-2013, 08:33 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Speaking of load securement I drive an 18 wheeler truck and yesterday I saw a flatbed dump truck(a c70 Chevy or about that size) lose a big generator on wheels. Left the red light and it rolled off from being improperly if at all secured.
Use straps on the front and back of the UTV. Make sure all are tight with no slack. Lock thr UTV in the lowest possible gear and park brake firmly set.
Do all that you should be golden.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 08-21-2013, 09:40 PM
eethomas's Avatar
eethomas eethomas is offline
Vehicle: 2012 Ram Laramie Longhorn
Trim Level: Longhorn
Color: Black & Gold
Rep:15
eethomas is on a distinguished road
If you look under the coupling at the locking mechanism, there should be a nut on the locking arm. The locking mechanism can be loosened or tightened by adjusting this nut. Sounds like yours is just a little too tight. Try backing off of this nut a little just until you can lock it down. Make sure that you don't back off too much. Sounds like about a half turn will do it. Try a half turn at a time and when you can lock it down STOP RIGHT THERE!! DO NOT LOOSEN ANY MORE!!
Eric Thomas
2012 Laramie Longhorn
Old 08-22-2013, 12:51 AM
Canadian Hemi Pride's Avatar
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
Working at an RV dealership it is extremely scary seeing how many people try to tow with the wrong size ball and all the errors they make. Great responses by members here.
If the latch is still not closing when there is weight on the ball.. Eithor push the trailer back or move the truck forward a bit.. The ball could be sitting to far back on the coupler and causing the latch from being able to properly close down. And yes always make sure to cross the chains and to plug in all electrical and that all lights/ brakes are working properly before ever leaving for a destination. A large percentage of accidents happen 5 minutes from home or 5 minutes from reaching a destination.
Always make sure that the UTV is properly secured with straps. It is always better to overkill and have the load properly secure then to underkill and risk the chance of having a UTV flying off the back of your trailer into traffic when a sudden traffic problem happens (being cut off, loss of control).
Tow mirrors up for the haters
Old 08-25-2013, 01:35 AM
Rep:13
A quick update to thank you all for your advice. The tips i received here were spot on. I adjusted the nut under the coupler and the tow ball fits perfectly into the trailer arm and everything locks into place perfectly. I've now managed to load up the UTV without any issues. Much appreciated!
Old 08-25-2013, 03:51 AM
eethomas's Avatar
Color: Black & Gold
Rep:15
Good Deal. Glad you got all of your issues corrected. Now go have fun & stay safe out there.
Eric Thomas
Old 08-25-2013, 11:59 AM
naturecannon's Avatar
naturecannon naturecannon is offline
Vehicle: 2012 Ram 1500 Quad
Trim Level: Bighorn
Rep:286
naturecannon is a jewel in the roughnaturecannon is a jewel in the roughnaturecannon is a jewel in the rough
At first, OP looked like a troll post for sure. Then I thought if not, these guys are going to tear this dude up.
After reading.... WOW, well done guys
Reps to all as i can
Bilsteins 5100, Magnaflow 18, Lines X liner, Airlift 1000, Toyo Open Country A/T II, Cabin Filter, Bully Dog, Billet Catch Can, 3.92, Low Profile ToolBox, Front Cab Window Tint
