newbie lift question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-22-2013, 09:28 PM
tburt93 tburt93 is offline
Vehicle: 2009 dodge ram 1500
Color: Deep Blue
Rep:12
tburt93 is on a distinguished road
Default newbie lift question
I already have 35s and a 3 inch coil spacers on my 2009 ram and want to go a little bigger, could I go to the bilstein 5100s and a body lift for about 4-5 more inches and keep coil spacers so a total of 7-8 inches of lift or do I need to get rid of the spacers to use those shocks?
Old 08-22-2013, 10:17 PM
Moderator
Rep:2140
First off, you have a 3" leveling kit on your truck? Are you 2wd or 4wd? If you're 4wd that's too high of a lift for the front end. It makes your CV shaft and control arm angles too high. You should definitely get under there and check them out. Snap a few pictures and post them up if you want some opinions.
Bilstein 5100 adjustables are for 4wd leveling or adding additional front end lift to a lift kit. You cannot run the Bilsteins and a leveling kit without doing a diff and cross member drop.
If you want more lift your options are either a body lift (cheapest, and half assed IMO) or to do a proper suspension lift.
Old 08-23-2013, 09:42 AM
shears's Avatar
shears shears is offline
Vehicle: 2009 Dodge Ram 1500 Sport
Rep:47
shears is on a distinguished road
^^^ I agree completely with him. Any higher than you are now and the Front Diff needs to be dropped. I think your only option is a lift kit as body kits are gross. Makes me puke every time I see one. haha
I also wouldn't go higher than 6" of lift on a 1500 any way.
Basically if you want more height than get a proper 6" lift kit and put bilsteins in the front to level it or don't if you want rake.
6" BDS Lift, 35x12.50x18 Nitto Trail Grapplers, 18x9 XD Addicts, FlowMaster Super 10, S&B Cold Air Intake, Solar Gard 20% window tint, WeatherTech DigitalFit floor mats, Debadged, Plasti-Dipped Grill and rear ram head emblem, Tow hooks
Taking Donations for more mods...
Old 08-23-2013, 12:42 PM
Wandell's Avatar
Wandell Wandell is offline
Rep:35
Nothing wrong with a properly designed and installed body lift like those manufactured by Performance Accessories. I lot of people will jerry rig or half a$$ install a body lift, resulting in a truck that looks like crap. When it comes to a body lift, it's the small details that make the difference.
2012 Ram 2500 4x4 ST Crewcab, Cummins 6.7, RCX 5 inch lift, 22x12 Fuel Mavericks, 35 inch Toyo MT's, H&S XRT Programmer, MBRP exhaust
Old 08-24-2013, 12:12 AM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
I'd like to know as well if you have a 2wd or 4wd
Also, what is your exact setup and brand?
sales@revelperformance.com
