Old 08-21-2013, 11:13 PM
Cyr220 Cyr220 is offline
Vehicle: 2000 Ram 1500 Club Cab 2wd
Color: Beige
Rep:17
Cyr220 is on a distinguished road
Default Starter issues
So I went to start my truck today and it turned over for half a second and didn't start. Proceeded to check the different fuses and see the 20amp starter solenoid was blown. Replaced and still no start just hear a single click. Tested volts on starter and battery getting around 12 v. Decide to try to bypass the plug at the starter to rule it out still only hear starter clicking. Replaced starter and still having the issue. Any help would be great. 1500 5.9l v8 2wd 2000
Having some tranny issues but can talk about that later.
Old 08-22-2013, 12:21 AM
RogerRamJet's Avatar
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2933
Get a breaker bar with the correct size socket on your crank pulley and make sure your engine is not seized up.
Old 08-22-2013, 06:41 AM
Color: Beige
Rep:17
A little extreme don't you think I've had zero mechanical failures and it was running 20 minutes prior
Old 08-22-2013, 09:34 AM
Color: Beige
Rep:17
Motor is not locked up put breaker bar on it and turned fine.
Old 08-22-2013, 11:44 AM
Rep:2933
Maybe a bit extreme, but with you putting a new started on and still not cranking, it's a simple action to make sure.
Next I would check the battery. Maybe it just doesn't have enough umph to crank the starter over.
Old 08-22-2013, 04:57 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Check battery and connections.
Old 08-28-2013, 10:45 AM
Color: Beige
Rep:17
Turns out it was the starter and the terminals on the battery.
Old 08-28-2013, 05:45 PM
Rep:2933
Excellent! Glad you found it. Reps for the find.
starter. wont turn over
