Old 08-22-2013, 09:00 AM
vanip vanip is offline
Vehicle: 2012 ST 4X4 Regular Cab
Rep:37
vanip is on a distinguished road
Default Anyone use Traxxx Lift?
I did the search and all I come up with are people using the leveling kit. The kit I am considering is Truxxx / Traxda COMPLETE Lift Kit 2009-2012 Dodge Ram 1500 4WD 5Lug 2" Front Lift 1" Rear Lift part #604012 that lifts the front 2" and rear 1". It's either this or the bilsteins. It says it's new. Just looking for someone with experience with this particular lift. Thanks
Old 08-22-2013, 09:06 AM
casper97ta's Avatar
casper97ta casper97ta is offline
Vehicle: 2013 Ram PowerWagon Crew Cab
Rep:27
casper97ta is on a distinguished road
That kit is basically a leveling kit with a 1" rear coil spring spacer. Actually thats exactly what it is. It uses a spacer in the front to level the truck 2" and then the 1" rear coil spring spacer.
IMO you are better off using the Bilsteins, you will get better ride quality and more options should you ever decide to add more lift in the future.
Mods
6" RCX - Bilsteins @ 2.1 - 1" TGC rear spacer - 37x13.5x20 Amp Terrains on Stock chrome - Superchips 3865 on 93 with trans tune - Vararam - Bully's 87mm TB - Magnaflow 14" - DeeZee Tailgate Assist - Bakflip G2- Debadged - 2500 Pocket flares - Cabin Filter - 2 12" Sundowns in Foxbox
Old 08-22-2013, 09:09 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
you could do that. I've heard of a few guys running that brand and they liked it.
you could also do the bilsteins and a spacer from top gun customs or the like.
thats a popular combo as well
Old 08-22-2013, 09:33 AM
Rep:37
Thank you-the kit is about $130 (for parts) cheaper AND cheaper to install as far as labor since I cant do it myself. I know the Bilsteins are probably the way to go, but price is also a factor!
Old 08-22-2013, 09:48 AM
Rep:1900
just remember you get what you pay for.
Not saying your kit is cheap quality. but there is a reason bilsteins cost what they cost. They are a reliable method of leveling that satisfies almost every user.
I see no reason not to go with other kit though.
Old 08-22-2013, 10:04 AM
Rep:37
that's kinda where I am at too! Thanks
Old 08-22-2013, 10:23 AM
casper97ta's Avatar
Rep:27
If you want to save a little more and not sacrifice quality, you could always just get the 2" front leveling spacer and 1" rear spacer from Top Gun Customz.
Mods
