6.4 crank in a 5.7 block? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-22-2013, 07:25 PM
ericlee9386's Avatar
ericlee9386 ericlee9386 is offline
Vehicle: 2011 Dodge Ram
Rep:36
ericlee9386 is on a distinguished road
Default 6.4 crank in a 5.7 block?
Hello friends I am looking to build a budget forged motor. I don't want to go all out as this will just be a boosted DD. I really want a 383 but was wondering if I could put together something a little better. I was thinking since the stock 6.4 crank is forged that maybe a good place to start and what displacement if any would this create?
http://www.campbellenterprises.com/5...ons-wiseco.php
Here is a site of the pistons I was looking at anybody have any experience with these?
An lastly since this isn't a racing motor is it even worth it to forge the entire motor if I am only planning on running 8-12 lb's of boost? I was thinking that maybe just replacing the pistons and rods would that work or No? Of course I don't want to be cheap but I don't want to over build. Along with this I was planning ported heads and a custom 268 cam (mix of the 266 and 270 comp cams) should be good for close to 530rwhp.
So any thoughts?
Performance mods
2800 stall, moes ported throttle body, vararam intake, ARH LT, Flowmaster 10 series, Hemifever tune.
Best 1/4 mile: 14.30 @91 mph soon to be 13's
Old 08-22-2013, 11:27 PM
Rep:3347
If you're only planning 12psi boost then you might want to just look at swapping the pistons as they're the weak point. The stock 5.7L crank isn't must of an issue at all as there are few failures with it. Connecting rods are a possibility but not a must. I don't know of any 6.4L crank swaps yet, but I do know that the 6.1L crank is forged and will bolt in, you just need to get one with a 58-tooth reluctor wheel as the stock one has 32 teeth. Manley makes a 58-tooth 6.1L crank OR you can swap reluctor wheels like mine.
Old 08-23-2013, 05:02 PM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2016 Ram Quad Cab
Rep:15
Fasthemiram11 is on a distinguished road
Wiseco is a good piston.. Had them in my old motor.
Sold that motor and its still going strong.
2011 RCSB 12.41
2012 RCSB 13.99
2016 QCSB 13.8
1992 Turbo Hemi D150 really fast times coming
