Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 1st Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-22-2013, 09:05 PM
Big Rig Ronnie's Avatar
Big Rig Ronnie Big Rig Ronnie is offline
Vehicle: 2006 Dodge Ram Mega Cab
Big Rig Ronnie is on a distinguished road
Default ac and heat only blow when im on the throttle
i have a huge problem i got the 2003 dodge ram slt 4.7 and my heat and ac dont change where i want it to blow and also if its cold out and i turn the heat on it blows cold air till i start moving and then it gets warm but as soon as i stop it blows like outside air. same for the ac if im on the highway driving it blows cold but as soon as i stop at a light or parking lot it starts blowing hot air like outside temp maybe hotter im not sure what is going on winter is coming and i dont wanna feeze my balls off.... help me
Old 08-23-2013, 11:57 AM
KingofDomain's Avatar
KingofDomain KingofDomain is offline
Vehicle: 2011 1500 Dodge Ram
Trim Level: SLT Quad Cab
Rep:74
KingofDomain will become famous soon enough
I had the same problem on my 2003, the motor went out on the fan that cools the radiator for the a/c & heat. When parked; pop the hood, turn on your a/c and check under the hood to see if the fan is turning (it should be the fan that's next to the driver sides head lamp). My fan motor when out because the connections were installed facing up (factory) why it wasn't designed facing down is beyond me, water had gotten inside and fouled out the connection. If this is the case it needs to get fixed soon will cause other problems.
Old 08-23-2013, 04:16 PM
Nabby Nabby is offline
Vehicle: 1991 Dodge Ram
Trim Level: Unknown
Color: Blue
Nabby is on a distinguished road
On you condenser, there is a fan that looks roughly like this: http://www.amazon.com/Dorman-620-035.../dp/B001CA8W6Q
Make sure it's moving when the a/c is on. If it's not, make sure to check the fuses before you consider replacing the fan. That's the most likely culprit for the a/c problem.
As far as heat, the problem usually comes from low coolant or air in the coolant line, stuck open thermostat, or at the very worst, a weak water pump. Does your truck come up to temp normally, and hold temp properly? No overheating?
Old 08-24-2013, 08:08 AM
Ok the fan does not move when I turn the ac on still gotta check the fuses but thank you guys for putting me in the right direction.. what about my control it blows in my face and thats it I can't change it i assume its a blend door or something but how much of a pain in the ass is that
Old 09-01-2013, 01:45 AM
Trim Level: Unknown
Color: Blue
There's a LOT of screws, panels, and wiring plugs to get apart. It's not difficult, but tedious and time consuming. I suggest checking out this video, it shows how to get all the panels off and where the doors are in the vent system.
Part 1 http://youtu.be/KAclL84Qq8E
Part 2 http://youtu.be/XRo1ook3v9I
Part 3 http://youtu.be/Hu0BIvhDT8E
