Old 08-13-2013, 05:19 PM
DBacksFan DBacksFan is offline
Vehicle: 2013 Dodge Ram 1500
DBacksFan is on a distinguished road
Default Bumpy Braking
I recently purchased a new 2013 Ram 1500 Express, crew cab, hemi 6spd 2wd. I've got about 400 miles on it and have just recently noticed something strange with the braking.
Whenever I'm sitting in traffic and scoot the truck up by lightly taking pressure off the brake pedal until the truck starts to move, there is a jerking or bumpy feeling in the truck. It goes away when the pedal is pushed harder or released completely, so basically it only happens when dragging the brakes and inching forward. I don't think the rotors can be warped, because braking from speed is smooth, and when the bumpiness occurs, the truck is moving so slowly that the wheels are barely turning.. Is this normal for these trucks? My initial reaction was that as the engine turns over, it tries to push the truck and creates a bumpy feeling, since the brakes are so lightly applied. I have a feeling that's not what it is though, since I've never experienced this in another vehicle. Has anyone else experienced this in a brand new truck, and any idea what causes it?
Old 08-13-2013, 05:49 PM
Grimass Grimass is offline
Vehicle: Ram
Rep:76
Grimass will become famous soon enough
It sounds like you may have a warped rotor. (It happens) If it is easily reproducible, take it to the dealer when you have a chance.
Old 08-13-2013, 07:00 PM
Ramzaq Ramzaq is online now
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
Could be the brakes need a little more breaking in. Try going on a back road and do a few hard stops (not panic stops) and not to many to overheat the brakes.
Then give it another low speed test and see if it is any different. If not take it into the dealer to be checked.
Old 08-13-2013, 10:28 PM
Gatsy92 Gatsy92 is offline
Rep:21
Gatsy92 is on a distinguished road
Mine also does this I know exactly what you mean. It's almost like an earthquake in your truck. Everything shakes.
Old 08-14-2013, 04:09 AM
ValleyRacer ValleyRacer is offline
Vehicle: 2013 Ram RT
Trim Level: RT
Color: Steel Blue Metallic
Rep:136
ValleyRacer will become famous soon enoughValleyRacer will become famous soon enough
Default Suspension travel and rubber bushings
New brakes (new pads & rotors) have a terrific "chomp" (well stopping force) and the truck's mass movement is felt as a chassis shift when the rotor & pad pressure just changes a little bit.
Or as you just inch forward you feel suspension movement due to rubber bushings, cab mounts etc
If you feel a "wobble" in the steering wheel during braking you could have a warped rotor.
If in a few more hundred miles the same thing is occurring it would be OK to discuss w/ the dealer.
Old 08-14-2013, 03:09 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I think you are just feeling the vibrations going on between the rotor and the pads. The HEMI is a beast and wants to be unleashed. Even at idle, there is a lot of kinetic energy, and with the slight amount of friction going on with just creeping forward, it's vibrating like a 5.7 on the Richter scale.
Old 08-16-2013, 08:35 PM
rizzkid12 rizzkid12 is offline
Vehicle: 2013 Ram1500 4x4 3.6l 8 speed
Trim Level: Tradesman
rizzkid12 is on a distinguished road
may sound crazy but it may be the gas sloshing in the tank. I have the 32 gallon tank and when it is 1/2 to 3/4 full I feel it slosh and bang a bit when I apply the brakes when in slow traffic.
Old 08-16-2013, 09:23 PM
Color: green
Rep:643
i would rule out the the gas slosh first.
Old 08-23-2013, 08:44 AM
Rusty289's Avatar
Rusty289 Rusty289 is offline
Vehicle: 2014 Ram 1500 Crew Cab
Rep:117
Rusty289 will become famous soon enoughRusty289 will become famous soon enough
I don't think it's braking or gas sloshing, my 2009 does the exact same thing and to me it feels like a tourque converter issue. Its most definitely in the drive line not the brakes, I've chalked it up to one of those things that my truck does. LOL
If ya can't Dodge it, Ram it!!!
Old 08-23-2013, 03:41 PM
ZMW ZMW is offline
Vehicle: 2013 Ram 1500 SLT 4x4 V6
ZMW is on a distinguished road
I have 2013 4x4 slt V6 - I notice that when braking from 40-50 mph and I get down to maybe 10 mph I feel the truck shimme a little. I always thought it was downshifting into 1st gear and it was slowing itself down on top of my braking...
