Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > Dodge Ram 4x4 - Offroad Discussion
Dodge Ram Decals
Old 08-23-2013, 10:07 PM
Mprimo's Avatar
Mprimo Mprimo is offline
Vehicle: 2011 Ram 1500 Crew 4x4
Rep:12
Mprimo is on a distinguished road
Default Leveled now what?
So I pulled the trigger on a set of bilstein 5100 and a 1" rear spacer. I really need help with tires and rims. Would like 35's and no rubbing. Anyone have some good ideas? Oh, I got the rear spacer so I could set the bilsteins to the max.
Old 08-24-2013, 03:44 AM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
If you set the Bilsteins to max you'll clear 35's no problem. The width is what you need to be concerned about. Typically to fit anything wider than a 285 on the stock wheels will require 1/4" spacers. If you go with aftermarket wheels you just need to order the correct offset. Typically 0 or -12 for a 9" wide rim.
Old 12-01-2014, 12:20 AM
canadianEH266 canadianEH266 is offline
Vehicle: 2015 Ram 2500 Power Wagon
Trim Level: Power Wagon
Color: Maximum Steel
canadianEH266 is on a distinguished road
Couple days ago I got a 2.5 pro comp level. Mayhem wheels with a +18 offset wrapped with Atturo Trail Blade MT's 35x12.5x20 no rubbing and rides just as good as stock
Old 12-07-2014, 08:21 PM
StrikeSwiftly StrikeSwiftly is offline
Vehicle: 14' Nightmare Express Ram
StrikeSwiftly is on a distinguished road
I run Bilsteins at full lift and a 1 1/2 rear spacer. Will soon be moving back down to a 1inch spacer myself. From reading the bils settle around 2.6 lift so my 1.5 in rear is just a bit over kill since I do zero towing at this point.
FYI IMO the ride quality has not suffered at all, only the 35 MTs change the ride quality.
Old 12-08-2014, 12:05 PM
nToxik nToxik is offline
Vehicle: 2012 Dodge Ram 1500 4x4
Trim Level: Outdoorsman
Color: True Blue Pearlcoat
nToxik is on a distinguished road
Which rear 1" spacer did you use?
Bilstein 5100s @ 2.1", BakFlip FiberMax tonneau
Old 12-08-2014, 07:50 PM
Moderator
Rep:2140
I would bet on Top Gun Customz. They're one of the only companies that makes 1" rear spacers for the 1500's.
