Old 08-23-2013, 11:09 PM
10chryslerhemi 10chryslerhemi is offline
Vehicle: 2010 chrysler
Trim Level: 2500
Color: gold
10chryslerhemi is on a distinguished road
Default 2000 ram 5.9 problems
start up cold idles rough, smell of gas, lack of power boggs like a carb,then warms up good and runs fine, no codes set, replaced wires-cap-rotor-throttle body gasket, looked down into intake no oil-any ideas?????
Old 08-24-2013, 03:29 AM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
MAP sensor comes to mind. Input from MAP is used in open and closed loop operation. A warm engine will better tolerate a run-rich situation which is why it smooths out once warmed up, and maybe the O2 sensors are able to correct for it to a degree. Typically, when a MAP fails, it generates a rich condition. Anyway, it's where I'd start.
Old 08-24-2013, 05:45 AM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Default What he said
ditto...........r...
Old 11-13-2013, 01:14 PM
jgt1969 jgt1969 is offline
Vehicle: 2001 Dodge Ram
Trim Level: SLT Laramie
jgt1969 is on a distinguished road
Did you try to disconnect the coolant temp sensor? disconnect the sensor then start the engine to see if there is a diffenence. You may have a bad cts.
