Old 08-25-2013, 06:08 PM
Astartes Astartes is offline
Vehicle: 2010 4.7l v8 4x4
Rep:160
Astartes has a spectacular aura aboutAstartes has a spectacular aura about
Default truck stuck in park
The problems never end ... Well I got my truck all fixed up or so I thought. They claimed it was perfect after I complained over and over that they should check the fluids which they didn't. I drove the truck home from the mechanic and parked it, now its stuck in park. Any idea?
Greater love has no one than this, that a man lay down his life for his brothers. -John 15:13
My Mods
Old 08-25-2013, 07:10 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Default Linkage
My guess would be your linkage is in bind (assumes your transmission levels in the automatic are fine). R...
Old 08-25-2013, 08:04 PM
will36 will36 is offline
Vehicle: 2010 R/T RAM
Trim Level: R/T
Color: BLUE
Rep:274
will36 is a jewel in the roughwill36 is a jewel in the roughwill36 is a jewel in the rough
Its the lock. check your fuses. Also check your brake switch. I know toyota's will not come out of park if the brake switch is not working. It should have a over ride.
Old 08-25-2013, 09:06 PM
Rep:160
All fuses have been replaced
My Mods
Old 08-25-2013, 10:42 PM
82corvette's Avatar
82corvette 82corvette is offline
Vehicle: 2012 Ram Crew Rambox
Trim Level: Laramie SLT
Rep:128
82corvette will become famous soon enough82corvette will become famous soon enough
Make sure all brake light bulbs are good
Old 08-25-2013, 10:47 PM
Trim Level: R/T
Color: BLUE
Rep:274
This the truck that got flooded?
Old 08-26-2013, 11:07 AM
Rep:160
Yes it was flooded
My Mods
Old 08-26-2013, 04:18 PM
skytop's Avatar
skytop skytop is offline
Vehicle: 2014 Dodge Ram
Rep:420
skytop is just really niceskytop is just really niceskytop is just really niceskytop is just really niceskytop is just really nice
Isn't this the 2013 truck of the year? You are asking him if the brake bulb is working which may be keeping his tranny in park? Really?
Find out where the reset button is and hit it with a hammer.
Old 08-26-2013, 04:43 PM
Trim Level: R/T
Color: BLUE
Rep:274
It very well could be the bulb. More than likely just a loose nut behind the wheel.
Old 08-28-2013, 01:56 AM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
is it parked on a hill? if it has too much pressure on the park lock it won't allow it release from park. if it's on an incline get a couple guys to try pushing the truck as you try taking it out of park. if that don't work block the tires and set the park brake get a buddy to hold the brake as well and go under it with it running and take off the shift linkage and try shifting it into drive from under the truck.
