Old 08-25-2013, 11:05 PM
mids mids is offline
Vehicle: 2013 ram 1500
Rep:73
mids will become famous soon enough
Default 2013 1500 Alpine dash speakers
I just ordered two pairs of Infinity Kappa 32.9cf speakers and speaker wire adapters. How do I go about removing the Alpine 3.5"s in the dash, on a 2013 Big Horn with the Alpine system?
I am hoping, that the -3db cut option for the tweeter, creates enough of a difference to create a center channel that has presence, but is not overpowering.
Before anyone asks why two pairs, the wife prefers the sound with the center speaker active, however, she feels that the system lacks clarity and highs.
Black 2013 RAM 1500 Big Horn 4x4 QC with 8spd, Hemi, air suspension, 3.92, 8.4AN, Alpine audio, anti-spin rear. 17" rims, and 3x Infinity Kappa 32.9 in dash location.
Old 08-26-2013, 03:28 PM
bstc00's Avatar
bstc00 bstc00 is offline
Vehicle: 2009 Ram 1500
Color: Inferno Red
Rep:184
Just pop the little cover of with a screwdriver and there are three bolts that hold down the speakers. Thank those of and install its that simple.
kkreit01 kkreit01 is offline
Vehicle: 2012 Ram CC 4x4
Trim Level: Outdoorsman
Color: Sagebrush
Rep:87
kkreit01 will become famous soon enough
Assuming the '13 is the same as the '12s, the grills just pop off. I've done mine so many times, I can remove with my fingernails. The center grill cover will have a wiring harness to unplug -- before removing completely. Tape this harness off to the side. It once fell down, and I had a difficult time getting it back. The speaker screws for the center speaker are also a pain. A 1/4" ratchet was too large, and I didn't have a wrench that small. It's either 7 or 8 mm. I used a socket, and turned with pliers. I now have a micro socket set that works great.
Old 08-30-2013, 10:46 PM
Rep:73
Ok, speakers came in today. Dash came apart nice and easy. Then discovered, that I was sold the wrong speaker adapters. Have to wait a few more days, I ordered the adapters from Crutchfield this time around.
In the process of removing the dash speaker grills, I discovered, that an expired credit card/room key/ID/etc. makes the job a snap. Just use it to pry the grill up from the side.
Old 09-08-2013, 01:08 AM
Rep:73
Everything came in on Friday, and I installed everything today.
Install impressions: The kappas fit nicely into the dash's side locations, however, the center location is a very tight fit due to the kappas permanently attached crossover. It did finally fit though.
Putting the grills back in place, I realized, that the rings needed to be removed from the speakers for clearance. The grills closed, but did not sit right with them in place.
Sound quality impressions:The sound quality improved substantially. The muddiness cleared up quite a bit, however, not completely.
Further thoughts: I am considering replacing the door speakers next, however, I am just not certain, how much further putting 6 1/2" or 6 3/4" woofers in the doors would improve the sound, or, if there a large loss, or change, of bass/mid-bass reponse. We really like how tight the bass and mid-bass currently sound, however, we have not reached the level of overall clarity that we are looking for.
Old 09-09-2013, 09:46 AM
autokraftgt autokraftgt is offline
Vehicle: 2011 2500
Trim Level: big horn
Color: grey
Rep:31
autokraftgt is on a distinguished road
adding a nice amp to power your speakers will improve clarity a lot.
head unit power is the dirtiest power out there....especially when you are asking the HU to power more than two speakers...
An amp will wake up all speakers you have now...by a ton!
Old 09-09-2013, 06:42 PM
Rep:73
I thought that the Alpine system already used an outboard amp.
Old 09-11-2013, 04:31 PM
Vehicle: 2011 2500
Color: grey
Rep:31
Oh they do....but I said to add a NICE amp
Old 09-11-2013, 11:58 PM
Rep:73
Which amp(s) would you suggest? Last time I bought an amp, was the late 90's
Would you just add the new amp in-line? Wouldn't that just end up amplifying the already noisy signal
Old 09-12-2013, 12:24 AM
ONOutdoorsman's Avatar
ONOutdoorsman ONOutdoorsman is offline
Vehicle: 2012 Ram CC 1500 4X4
Color: Black (PX8)
Rep:388
ONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really niceONOutdoorsman is just really nice
I added Infinity Reference 3032cf dash speakers and removed the centre speaker on my 2012. I will never look back. The sound and stereo separation is 1000 times better.
I added the dash speakers and sub/amp combo and it sounds fantastic IMHO. Something to think about.
