Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum
Old 07-20-2013, 10:17 PM
nikeman nikeman is offline
Vehicle: 2013 Ram Sport 1500 True Blue
Rep:91
nikeman will become famous soon enough
Default Scratch removal
I went up to the smokey mountains for 5 days and got home today and found a small scratch beside my fuel door. I went through a lot of narrow roads with overhanging branches so I'm sure a stick hit it. Not a huge deal but I'd like to fix it to prevent rust. I have fixed a scratch on my old truck but after close to 2 years that touch up paint had basically all came off some how. Apparently i didn't do something right that time.
My plan:
Get touch-up paint
Wash truck
Rub scratch with rubbing alcohol and dry
Brush on paint and let dry at least 3 coats
Maybe put a layer of wax on final coat???
Last time I attempted this it was freezing cold outside and that probably played a roll as to why it didn't last long. Any other tips?
Old 07-21-2013, 10:44 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
if you drag the back of your fingernail across the scratch, does it catch?
Old 07-21-2013, 02:12 PM
Rep:91
Yes. Its pretty deep probably to the primer.
Old 07-21-2013, 02:53 PM
JWM59's Avatar
JWM59 JWM59 is offline
Vehicle: 2013 Dodg Ram
Rep:148
JWM59 will become famous soon enoughJWM59 will become famous soon enough
What I like to do is buy the correct touch up paint from the dealer or use Duplicolor. I also use Dupicolor clear coat. I apply the color coat first and let it sit for about a half hour. Than I buld up the clear coat until it sits slightly higher than the cars finish. Letting it sit for an hour or so between coats depending how big the chip is. Than the following day I wet sand it down with 2000 grit until flush with the cars finish. I like to use a magnifying glass as an extra precaution. Than I buff out with 3M compound. I have a classic Mustang that I drive to shows and shit happens so I learned how to deal with my own touch ups plus I don't trust people touching my stuff especially when I fell I can do a better job. If done correcty it would be very difficult to see the repair. Naturally some colors touch up easier than others. Make sure you prep the surface free of wax and dirt.
Old 07-21-2013, 06:59 PM
Rep:91
So I should only put one coat of the dealership paint on there with several layers of clear? I didn't put any clear on it on the old truck.
Old 07-23-2013, 04:06 PM
JWM59's Avatar
Rep:148
That would be the best way and less noticeable repair.
Old 07-23-2013, 07:27 PM
Chris11Ram's Avatar
Chris11Ram Chris11Ram is offline
Vehicle: 2011 Dodge Ram
Chris11Ram is on a distinguished road
Check out Langka - Paint Chip Repair
Old 07-26-2013, 09:59 PM
Rep:91
I like the look how easy the langka looks but how much is the kit? I didn't see a price and I'd have to buy the paint which isn't to cheap either for the little bit you get.
Just so I have an idea, how much would a body shop charge to fix a 1" scratch? Would they just do a touch up method or would they want to paint the entire panel?
Old 07-27-2013, 09:42 AM
Chris11Ram's Avatar
Paint Chip Repair Kit
$39.95 each
Old 07-27-2013, 09:55 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
g/l alot of these paint repairs dont work or when done you can still see the area i have black so every chip i get the grey primer jumps right through i have yet to find anything that looks good
And as far as paint shops some will do a touch up but must want to paint whole thing
