Vibration only at 40mph? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 08-26-2013, 07:37 PM
DevinC's Avatar
DevinC DevinC is offline
Rep:193
DevinC has a spectacular aura aboutDevinC has a spectacular aura about
Default Vibration only at 40mph?
Hey guys, about 3 weeks ago I bought my new 2013 1500. Since then total miles are about 550, and I baby it.
However, lately I have noticed a strong vibration coming from the front end only when I am cruising in the low 40 mph's. It doesn't matter if I have cruse control set or not. If I am cruising above 45 or below 40 at any speed, no vibrations at all.
Since this is a new truck, is this normal? Has this been happening to anyone else? I figured I should post here before I take this issue to the dealership.
Thanks guys.
Old 08-26-2013, 07:51 PM
mrolow's Avatar
mrolow mrolow is offline
Vehicle: 2013 Ram 2500 4x4
Color: Prairie Pearl Clearcoat
Rep:132
mrolow will become famous soon enoughmrolow will become famous soon enough
Could be wheel balance. I had a vibration on my jeep at around 50-55 mph and once the wheels were rebalanced, no more vibration.
Mods: Too many to list
Old 08-26-2013, 07:58 PM
DevinC's Avatar
Rep:193
Thanks! That makes sense, I didn't even think of that.
Old 08-26-2013, 08:38 PM
MrPiper's Avatar
MrPiper MrPiper is offline
Vehicle: 2012 Ram 1500 Bighorn
Trim Level: 1500 Bighorn
Rep:54
MrPiper will become famous soon enough
Yes, get the tire balance checked, but if they say it was fine or the balance was only off just a little bit, see if the vibration continues. If it does, take it back and have them dismount the tires and check for a warped WHEEL. What you are describing could easily be either.
Old 08-26-2013, 09:06 PM
bowieknife's Avatar
bowieknife bowieknife is offline
Vehicle: 2013 Sport CC, 5.7L, 8spd
Trim Level: Sport Crew Cab
Rep:71
bowieknife will become famous soon enough
Send a message via Yahoo to bowieknife
It could be as simple as the MDS kicking in. That seems to be where I feel it the most. Try clicking the "Gear -" button once, then click the "Gear +" button until you get to "8". This disables the MDS but still cycles through all 8 gears. Then drive at 40 mph and see if the vibration is gone. If it is the MDS, then the vibration is normal. If not, out of balance wheel is a good guess..
Old 08-26-2013, 09:38 PM
DevinC's Avatar
Rep:193
Thanks! I had a feeling it might be the MDS, but this is a new platform for me so everything is new to me. I will try this tomorrow morning on the way to work. After I put it to "8" and check for vibration, I assume I click down 8 times to reactivate MDS?
Old 08-26-2013, 09:46 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Good info from all on this one. But, with the narrow window of MPH that this occurring in, it really sounds like a wheel weight. It is rare for them to come off, but if one gets loose and "slides" a little on the rim, there you go. JMO.
Old 08-26-2013, 10:28 PM
bowieknife's Avatar
Rep:71
Actually, hitting the "+" one additional time (if you're in "8") will get you back into MDS.
Let us know if you figure it out and what the fix is...
Old 08-27-2013, 12:21 AM
2013 Ram SXT's Avatar
2013 Ram SXT 2013 Ram SXT is offline
Vehicle: 2014 Ram 1500
Color: Bright silver metallic clearcoat
2013 Ram SXT is on a distinguished road
I had the same problem with mine as well. No hemi in my truck but it did come with 4 ply tires. After my dealer undercoated it thinking that it would help (no-charge). They agreed with me that it was the crappy tires on it. Upgraded to the factory 10 ply tires, no more vibration.
Old 08-27-2013, 07:41 AM
DevinC's Avatar
Rep:193
Default **Solved** Vibration only at 40mph?
Well I am only able to click it to "6" not "8" however, No vibration. When I reactivate MDS I feel the vibration. I just find it strange that I can feel it so much, but since it being new I just have to get used to it.
Thank you guys for all the help!
