Old 08-26-2013, 08:37 PM
rocketman rocketman is offline
Vehicle: 2011 ram 1500 Laramie
rocketman is on a distinguished road
Default which tires
I am buying a new 2014 sport all balck. I want to take stock tires off right away. I love michelin ltx m/s 2 ( I am in Atlantic Canada with snow) however they are not white wall. Can anyone suggest a good all season tires in 20" that have good tread life?
Old 08-27-2013, 12:13 AM
LowUFO's Avatar
LowUFO LowUFO is online now
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
Cooper Discoverer gets good reviews.
Simon
Old 08-27-2013, 06:39 AM
pld's Avatar
pld pld is offline
Vehicle: 2013 Ram
pld is on a distinguished road
If it was up to quality of tire and blackwall or white lettered, personally I'd run with the Michelins and blackwall;best tire out there especially where you live.
2013 black Ram Sport----------- CAI- Magnaflow 22" muffler (#12588) with resonator's deleted- 5"X12" MBRP polished tip's- Hemifever tune-BT catch can-180 degree T-stat-Ported 87mm throttle body-Cooper discoverer AT3 tires
Old 08-27-2013, 03:39 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Trim Level: Outdoorsman
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
I'd be carefull with cooper ST's--at least their older design, called ST instead of the newer ST MAX. My old truck ran them and they went out of round on me with less than 20K on them. The dealer told me they were known for that unless you rotated them every oil change (I used every other change).
Their less agressive all-terrain A/T3 design is good though. I I like the Toyo Open country's too. HT for road only or AT for some off road. The AT tread life is a looooong time in my experience. Go with E-rated for any heavy or serious off road use, c-rated otherwise (C's will ride a bit smoother too).
Cooper has a sale on now through november on a full set of tires.
Can you order with 17's instead of 20's? If so, and if snow is your big concern, the 17's will be a better option for you than the 20's will no matter what brand you buy.
