United Radio
Old 08-28-2013, 02:30 PM
CTR CTR is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: SLT, Big Horn
CTR is on a distinguished road
Default Bilstein installation issue
This probably could only come from a newbie. The Bilstein instructions for the 5100s indicate that you use the lower coil spring seat from the existing strut to put on the bilstein strut. With the crimped end cap on the factory strut, it doesn't look like the seat will slide over the end, to install on the new strut. (I have not completley dis assembled it to try). Does it come off? Easily? What is proper way to get that seat off. Already discovered that the lower spring seats don't seem to be readily available....Thanks
Old 08-28-2013, 02:50 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
tap that crimped end cap off with a hammer. easy as that
then the spring seat slides right off!
Old 08-28-2013, 04:03 PM
Lifted Cummins Fanatic
Rep:1990
brandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant futurebrandonjansen has a brilliant future
Yup, what gonefishin said above ^^ You might need to tap the spring seat a few times to get it loose as well. But it will all slide off.
8" BDS Long Arm Lift with Fox 2.0 Shocks | Dual Fox 2.0 Steering Stabilizer | 37x13.5 Toyo MT's | AMP Powersteps & Bedstep | Bakflip G2 | Mag-Hytec Rear Diff Cover | 5000K Morimoto HID's (lows and fogs)
Old 08-28-2013, 04:38 PM
CTR CTR is offline
Absolutely great, thank you both. I was concerned that I was going to turn one or the other of my hands into hamburger if everything came out of that strut. I'll post a progress note when I finish. I appreciate the help......CT
