Old 09-26-2013, 10:30 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Originally Posted by Johnz View Post
that sounds interesting, what kind of power increase are we looking at with the high boost with them forged piston?
Whats the price tag on a set of those?
$769
http://www.modernmuscleperformance.c..._p/mm-57lp.htm
Old 09-26-2013, 10:35 PM
Johnz's Avatar
Johnz Johnz is offline
Vehicle: 2012 Dodge Ram
Color: Cherry
Johnz is on a distinguished road
man that sounds interesting, so with all that one wouldnt be too far from 600whp with supercharger so i could get them installed and run them normally until i get my kit?
Old 09-26-2013, 10:51 PM
I push the skinny pedal
Rep:3283
Yes, they can be run with or without boost. Be realistic with your goals, 600rwhp will be at the top end of where you could dream of being. A more realistic number running just 12psi of boost with some water meth to keep it safe would be 525-575rwhp. The stock rwhp is around 340 and a Ripp is putting people around 460-475 depending on tuning (and if you got a stage II kit before they disappeared), altitude, etc. *currently* without much room to upgrade boost levels. There are lots of factors that affect your results, so keep that in mind.
12-14psi is also the max you'd be able to get out of the head unit Ripp uses. After that you'd have to upgrade to a V-4 or Ysi and completely retune.
Kurtis
Old 09-27-2013, 11:17 AM
Johnz's Avatar
Color: Cherry
Cool
Cool, I think im going to get them. Anyone know whats the ballpark price to get them installed?
Old 09-27-2013, 08:55 PM
Rep:3283
All depends on the shop you get to do it. I would do the swap myself if it was mine, but I'm handy around a hemi block. You need to pull the engine, tear down, swap parts, reassemble, and reinstall. It won't be cheap, probably an 18hr minimum to R&R, I'm not sure what the book states though. Takes me about 4 hours to prep engine/bay for removal and an hour to pull the block.
You don't have to pull the rotating assembly, just remove one con rod at a time, swap piston, and reinstall. Might be a good time to swap in ARP2000 rod studs or use new OEM ones.
Kurtis
Old 12-30-2013, 05:46 PM
Johnz's Avatar
Color: Cherry
Cool
Any news on the 2012's ripp supercharger/tranny/tuning?
How you making out with your truck Blackramhemi?
Old 12-31-2013, 07:25 AM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2012 Ram Express
Rep:15
Fasthemiram11 is on a distinguished road
Cool. so im out of luck for a while. ive got the 12. I guess ill just kick start my project with small mods. e-fans and catch can.
I'm lookin to pass my kit on to someone with time to work with Ripp on 2012 tuning.
PM me for details
2012 SOUTHERN EXPRESS
Had 2011 HEMI EXPRESS 12.4@111
Old 01-01-2014, 12:58 AM
NIck11 NIck11 is offline
Vehicle: 2014 Ram 1500 Sport 6'' BDS li
Rep:45
NIck11 is on a distinguished road
Question for everyone, I know it will be a while before we get a kit for the 2014 Ram 1500's. However when a kit does become available I plan on purchasing it.... before doing so I wanted to ask the question:
Given that the 8 Speed Transmission in the newer trucks are rated at about 140 ft-lb's of torque more than the 6 speeds, do you think a transmission build will be necessary?
I would be going for 6 lbs of boost, which would probably make around 550 ft-lbs at the crank.....
Old 01-01-2014, 08:44 PM
Rep:3283
Only time will tell with the 8-speeds. We need tuning for the '13+ to be able to get the HP up to a point where we will find the weakest link in the system. Now, ZF does make a great transmission and they have higher rated transmissions along the same 8-speed line, one of which will be going behind the stage III scat pack cars, so there may be hope for aftermarket support, especially given that it's finally the same transmission that's in the LX cars and not the bastard child of the Mopar community.
Kurtis
Old 03-29-2015, 11:46 PM
topsub topsub is offline
Vehicle: 2012 Dodge Ram Laramie
Color: Blue
Rep:156
topsub has a spectacular aura abouttopsub has a spectacular aura about
2 years have past since i started this thread, but i am going monday to order a procharger.
Ordering:
Procharger
ARH Long w/ Cats
efan
Mike is waiting for a core then starting a tranny build
SOON::
4.10 gears once i can find front axle / driveshaft
Should be a fun time!
2012 Dodge Laramie 4x4 CrewCab Supercharged and Lifted
My Build Progress
