My 4.7 liter is burning oil out the tailpipe need help - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-27-2013, 05:26 PM
1stdodgeram1500 1stdodgeram1500 is offline
Vehicle: 02 ram
1stdodgeram1500 is on a distinguished road
Default My 4.7 liter is burning oil out the tailpipe need help
I have a 02 dodge ram with about 140k. runs good but its burning oil out the tailpipe. I checked to see and hope it the plenum gasket thing but I dont think they have one i'm left puzzled. the pcv hose are cracked could that be it could it be a cracked intake im lost
Old 08-27-2013, 06:07 PM
brandonjansen's Avatar
Moderator
Trim Level: Laramie Limited
Rep:2140
Could be a number of things. Easiest things to check are the PCV valve and those areas but I wouldn't guess something that small would do it. I'd say the oil ring could be shot on one or more pistons.... That would be the most likely thing IMO.
Old 08-27-2013, 06:51 PM
Vehicle: 02 ram
the hose on the pcv valve are torn but could a pcv valve cause all of that does it sounds like a rebuild
Old 08-27-2013, 06:58 PM
Moderator
Rep:2140
If they're torn it definitely shouldn't be sucking oil through the PCV....
I'm thinking it's something within the engine so yes it would be a rebuild to find out what it is and fix it.
Old 09-04-2013, 08:21 AM
deanhinsley1963's Avatar
deanhinsley1963 deanhinsley1963 is offline
Vehicle: 2004 Dodge Ram 1500
Color: silver
Rep:12
deanhinsley1963 is on a distinguished road
Why do you say its burning oil out of the tailpipe? Is it oily? If so probably the oil rings. How does it run? And how much oil does it use? I would also do a compression check before I started talking rebuild.
Old 09-04-2013, 03:53 PM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
well depends on how it burns oil....upon starting, accelerating from stop, while cruising....It can leak oil different ways not just the oil rings, could be bad valve seals..etc
But check the intake and intake manifold or oil film....thats a good indication that pcv is bad....
Old 09-04-2013, 06:00 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Brandon & tj are correct. It depends on when/how it's losing it, and it could be a plethora of things. Wish it was a simple answer and/or simple fix, but it's not.
Old 10-25-2013, 12:48 AM
Vehicle: 02 ram
iys oil around the filter housing oil around the back of the intake looks i can tell you im lost it runs good for some odd reason thinking of getting rid of this truck for f-150 let me know what can i do this mopar is strange
