Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 11-13-2013, 06:01 PM
Ramshackle Ramshackle is offline
Vehicle: 2006 4 x 4 RAM w/Cummins
Ramshackle is on a distinguished road
Default Cummins engine issue
I am getting a distinct vibration whenever I approach 55-60 mph or going uphill. Let off on the accelerator and the vibration disappears. Checked U-joints and they feel tight. Any suggestions?
Old 11-13-2013, 08:28 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
I would replace em anyway. Cheap insurance, get ones that have grease fittings. While you get it up in the air, check all 4 wheel bearings. 55-60 is a speed that an out of balance tire might start to shake/bounce, whatever. If you rotate em front to back then the vibration feels different, thats it.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 12-08-2013, 08:15 PM
Rob M Rob M is offline
Vehicle: !992 D250 club cab 5.9 diesel
Trim Level: LE
Engine: 1989-1993 360ci (5.9L) Cummins diesel I6 160hp 400lb/ft
Rob M is on a distinguished road
If your truck has two driveshafts then check the hanger bearing. Hard to tell if the universal joints are bad by just trying to move them. Best way to check is unbolt them and pull the caps and have a look....
