Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Dodge Ram Decals
Old 08-27-2013, 10:47 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Trim Level: Outdoorsman
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
Default Inconsistent Remote start operation?
Left work today and tried the remote start--clear line of site to the truck, but it was some distance away--and it only honked once. Too far away to tell if it started. So I walk a bit more and hit it again. Only honks once. Get close to the truck, try it again, only honks once, engine is not running, and it won't start running.
Starts up fine when I get inside. Get home, step out, give it 30 seconds or so, and while standing right next to the truck, it starts up fine when I hit remote.
I was hitting remote twice as directed each and every time.
Any ideas what is up with this? I was hoping I could pop the window in the winter and start my truck from the office before heading out, but that doesn't look good now. Makes it moot if I have to walk close to the truck before it will work. Hope the heated seats warm up in a hurry--if they don't that wasn't worth the money either! At least I am not that far from the truck at home, hopefully it will work there without having to walking within 20 yard of it.
Old 08-27-2013, 11:09 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
Mine seems a little temperamental when it comes to hitting the remote start with the right timing. Too quickly and it won't start. Too slowly, same deal. Not sure if this is what you're dealing with, but this is my experience with the factory installed remote start.
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 08-27-2013, 11:40 PM
spoiler's Avatar
spoiler spoiler is offline
Rep:372
No idea on the temperamental remote but you can get the Uconnect app for your phone and remote start your truck from anywhere in the world*
Turn on the truck and heater without opening your office window :-)
* you know.... within reason
Old 08-28-2013, 12:14 AM
Klus01's Avatar
Klus01 Klus01 is offline
Vehicle: 2013 Dodge Ram
Klus01 is on a distinguished road
I hear ya on that one.. I find I have the most luck just hitting the damn thing 3 times. When I hit it twice it maybe works 60% of the time.
Still better than doing it the old fashion way on a cold morning though!
Old 08-28-2013, 09:21 AM
tev9999 tev9999 is offline
Color: Maximum Steel
Rep:39
tev9999 is on a distinguished road
Were you by any chance low on gas? There is a safety feature that will disable remote start so you don't run your tank dry. It has kicked in on me twice - both times the gas pump icon was lit so I assume that is the trigger. There was also a message on the display, but it does not stay active for long so if you don't look right at it you will miss it.
Starting when you got home would indicate this is not the case, unless you have a short drive and park on an incline that may change the level of fuel the gas gauge sees.
Old 08-28-2013, 11:51 AM
Monster5601 Monster5601 is offline
Vehicle: 15 Longhorn 3500
Trim Level: Longhorn
Color: Western brown
Rep:483
Monster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of lightMonster5601 is a glorious beacon of light
Hitting the remote start when the engine was started by remote will shut the engine down. When I remote start, the parking lights are on indicating a successful start.
2013 RAM 1500 CC Hemi Laramie 4x4 in Cherry Red
2015 RAM 3500 CC CTD Longhorn 4x4 SRW in Western Brown
Old 08-29-2013, 12:44 AM
Rep:92
Half a tank of gas so it wasn't an issue of low gas. The thing that threw me was it beeping just once--that seems to me to indicate a problem. If you don't get the pattern down right you'd think it wouldn't work at all, or not beep at all. There was one thing that happened before I shut the truck off that possibly may have led to it. I am not completely attuned to the dial shifter yet and pulled into a parking spot and shut the truck down without moving it to park. The new 8 speed dial system recognizes this electronically and mechanically shifts itself into park after a bit. Not sure why it would affect remote start, but I might try repeating this to see if it was the cause, and report back.
Old 08-29-2013, 08:27 AM
KJ48 KJ48 is offline
Vehicle: 2014 1500 Ram QC
Color: Blue Streak pearl
Rep:122
KJ48 will become famous soon enoughKJ48 will become famous soon enough
It will usually say on the EVIC why the remote was disabled.
If a door is not shut all the way it wont start and beep once, if the hood is open it wont start (the switch on the hood has been known to cause problems), if its low on fuel it wont start, if there is any kind of CEL it wont start etc.
It does take a certain timimg on the twice-press to get it to work, if I dont hear anything on the 2nd press the third press usually does it, Just have to be careful because if the remote start sequence begins another press cancels it. I think if you start it and cancel it twice it wont let you remote start ir any more, you have to start it regularly to reset it.
I start it regularly from 800-1000'' away line of sight so it has decent range. But like anything else these days it has many safety features that can stop it from working.
Old 08-29-2013, 01:11 PM
DarthRam's Avatar
DarthRam DarthRam is offline
Rep:1543
On my last truck I had an aftermarket AstoStart. It was amazing. I could start my truck from the second level of a building from 500+ feet away. It also had a 2-way system that would tell the remote if the truck was running, doors locked, etc. If the signal to start the truck wasn't received by the truck it would tell me that also.
So, with all the technology available today, why the sub standard remote start system on these trucks?
Old 08-29-2013, 08:32 PM
sofaking sofaking is offline
Vehicle: 2013 ram
sofaking is on a distinguished road
I had an autostart 2 way on my 08 2500 and it was awesome just like you said. It was programmed to wait 12 seconds I think with the ignition on before hitting the starter (diesel).
I haven't heard great things about the factory remote start and am wondering if I should look for an aftermarket system for my new truck (when I actually buy one). It gets damn cold where I am making a reliable remote start and important feature.
Can someone tell me how the U-connect feature works from a smartphone? I understand the principle but do you need some sort of subscription to make it work and is that subscription free for the first year on new trucks? Also i am an android guy not an iphone guy and I don't see any android apps for this.
