iiiiiiii have a probleeemmmmm - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 08-30-2013, 10:59 AM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:168
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
Getting to the plenum gasket isn't exactly tough. just time consuming, and requires a little planing to remember where all the frigging clips and bolts go. Gotta love the "where'd I get this extra bolt" when you think you're finished.
Livin life one truck payment at a time.
Old 08-30-2013, 09:59 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
so what would you all recommend? haha.
how to get to the gasket,
and how to clean the inside.(if necessary, its pretty gross looking.)
Green Interior LEDs
Old 08-30-2016, 04:16 AM
Pattipileloader's Avatar
Pattipileloader Pattipileloader is offline
Vehicle: 1991 Dodge Ram 150
Rep:71
Pattipileloader will become famous soon enough
Here's a step by step guide to replacing the plenum gasket and how to fix it completely for those who land here looking for a solution to this problem.
Dodge Ram 150 1991 3.9 petrol RWD ''Jötunn''
Dodge Ram 1500 1996 5.2 Magnum V8 4wd ''Týr''
Old 08-30-2016, 06:58 AM
Moparite's Avatar
Moparite Moparite is offline
Vehicle: 96 Indy ram - 96 2500 4X4
Rep:16
Moparite is on a distinguished road
Get the Hughes plate with felpro gaskets! Mine has been on about 10 years without an issue.
http://www.hughesengines.com/Index/p...p?partid=27091
Brakecleen!
Old 08-30-2016, 07:30 AM
airforce26yrs's Avatar
airforce26yrs airforce26yrs is offline
Vehicle: 2017 1500 Sport CC
Color: Copper Edition
Rep:77
airforce26yrs will become famous soon enough
I have heard that another way to check for vacuum leaks is to use starting fluid and spray it around while the engine is running. If the engine RPM's increase while doing this you have found your leak. I would not do it while the engine is hot but right after starting it.
Old 08-31-2016, 01:37 AM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: 2003 Ram Laramie 4x4 3.55 LSD
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver
Rep:185
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
Mopar M1.....just upgrade if you are in there already lol!
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
Old 09-03-2016, 10:06 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 15 BigHorn Ecodiesel
Trim Level: Big Horn CC
Rep:273
namretsud is a jewel in the roughnamretsud is a jewel in the roughnamretsud is a jewel in the rough
Brakecleen!
This .I did a Hugh's kit and it definitely resolves the cause of the manifold leak. The whole cause is an engineering disaster. You never put a gasket between 2 different metals (steel and aluminum) and expect it to stay in place due to different expansion and contraction rates when heated and cooled.
Old 06-11-2017, 12:41 PM
2ndgenguy's Avatar
2ndgenguy 2ndgenguy is offline
Vehicle: 1997 dodge ram
Trim Level: L T w/ AC
Color: emerald green metalic
Rep:20
2ndgenguy is on a distinguished road
Have you tried your idle module at back of throttle body
high, idle, problem
