Resetting throttle response? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 08-25-2013, 04:15 PM
Irv's Avatar
Irv Irv is offline
Vehicle: White 2013 QC 4x4 BigHorn
Trim Level: BigHorn
Rep:14
Irv is on a distinguished road
Default Resetting throttle response?
I remember reading on here about those that were asking about throttle response and why some seemed more peppy off the line than others.
I believe the fix, or at least a suggestion was to fully depress the throttle all the way to the floor slowly then release slowly?
Just curious who has all done this, and curious if it worked or not?
Also, do you put the key on at the ACC setting or the RUN setting (but not running of course)
Old 08-25-2013, 06:05 PM
pld's Avatar
pld pld is offline
Vehicle: 2015 Ram
pld is on a distinguished road
I was curious about this and did a search; it was from 2012 and the guy said to turn key to on position without starting engine and let it cycle through everything, slowly press gas pedal down fully for 3-5 seconds and slowly bring back up. Turn key off and it's suppose to reset. It worked for him and another guy but the other few that tried it ,didn't sound like it worked.
Old 08-26-2013, 07:43 PM
Irv's Avatar
Irv Irv is offline
Trim Level: BigHorn
Rep:14
Thanks, guess I'll have to try it and see if it works?
The reason I asked was because our 4.7 Ram at work is a lot more sensitive than what my 5.7 is, and my bud with also a 13 Ram with a Hemi says his is just like our work truck.
I haven't driven his to compare, but I have no reason to not believe him.
Was hoping the Ram Tech guy from Uxbridge would reply to this thread as I am sure he would know for sure? (Sorry, forgot his name)
Old 08-26-2013, 08:02 PM
Thunderhorse's Avatar
Thunderhorse Thunderhorse is offline
The Sound of Eight Hooves
Trim Level: Lone Star (MJX8)
Color: Bright White (PW7)
Rep:853
Thunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to beholdThunderhorse is a splendid one to behold
I did it too and I think it made it more sensitive, but I'm honestly not sure.
Thunderhorse:
2013 Ram 1500 Lone Star Quad Cab 4X4. Bright White (PW7), 345ci Hemi V8, 8HP70, 3.21 gears (LSD rear). Mods list
Colt:
2015 Durango SXT Southwest Heat RWD. White Knuckle (PW7), 220ci Pentastar V6, 845RFE, 3.45 gears (open). Huskyliners, Catch can. Thread
Old 08-26-2013, 08:03 PM
PaulMys PaulMys is offline
Vehicle: no car
Rep:3238
Irv, it works. I do this on occasion as I tend to drive like someone's grandma most of the time. The computer learns this, and adjusts accordingly. Hope this helps, signed: Grandma Paul. LOL!!
Old 08-26-2013, 09:40 PM
maust1's Avatar
maust1 maust1 is offline
Vehicle: 2013 Ram
Trim Level: Tradesman
Color: mineral grey
Rep:355
I did it to my 4.7L and it feels like a different truck. It can't hurt to try it.
Mick
Old 08-26-2013, 09:46 PM
BadAzz13Ram's Avatar
BadAzz13Ram BadAzz13Ram is offline
Color: Mineral metallic grey
Rep:18
BadAzz13Ram is on a distinguished road
So this technique is used to get a better throttle response?
Old 08-26-2013, 10:13 PM
2013Sport's Avatar
2013Sport 2013Sport is offline
Vehicle: 2013 Dodge Ram
Rep:20
2013Sport is on a distinguished road
I'll try it tonight on mine, its a little sluggish off the line.
Update:
Nothing changed. I tried (I have the push button start, don't know if it changes anything):
1. Run position
2. Depress gas pedal and let off (5 secs)
3. Off position
And
1. Run position
2. Depress gas pedal and left off (10 secs)
3. Off position
I drove around the block and tried the procedure a couple of different ways and nothing. It was raining all night, the truck barely chirps the tires with the traction control off. When is hemifever coming out with a tune already? lol
JR
Old 08-27-2013, 04:41 AM
maust1's Avatar
Vehicle: 2013 Ram
Color: mineral grey
Rep:355
Did you let the cluster and dash finish cycling through all it stuff before you pressed the gas.
Old 08-27-2013, 06:40 AM
Arth's Avatar
Arth Arth is offline
Vehicle: 2006 Chevrolet Avalanche
Color: Bronze Alloy Metallic
Rep:2035
I don't know if this little cycle thing works but I doubt it. If you want any sort of reset just disconnect your battery for a few minutes. This will erase all of the stored driving habits the computer has and it will start over again.
I know that will make the truck feel very different. Nothing crazy...just different.
Chrome... in moderation.
