Old 08-28-2013, 09:55 AM
ff6cav's Avatar
ff6cav ff6cav is offline
Vehicle: 2008 Dodge Ram
Color: Inferno Red
Rep:104
ff6cav will become famous soon enoughff6cav will become famous soon enough
Default Accessory Fuse Block
Has anyone on here tried putting in an accessory fuse block? I've been wanting to for a while to hook my accessories into(emergency response lights, CB radio, accessory lights). After some internet research on "other brand" forums, I think I have a handle on the basics of installing them, but I wanted to know if any other Ram owners out there have them and what, if any, issues you ran into?
"Little Red Wagon"
2008 Ram 1500 Big Horn
Old 08-31-2013, 01:35 AM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
I don't know of any, but this sounds like a pretty good idea. Hmmm, I'm gonna have to look in to that.
Old 09-02-2013, 10:48 AM
ff6cav's Avatar
Color: Inferno Red
Rep:104
Just placed my order for this one:
http://www.seaboundsupply.com/blue-s...2-circuit.html
Hoping it comes this week, and I will hopefully have it installed by next week, time permitting. When that happens, I'll post pics along with any issues I may have run into- maybe it'll help anybody else who is looking at doing this
"Little Red Wagon"
Old 09-02-2013, 10:54 AM
God Bless Texas!
Rep:2929
Excellent. Looking forward to the write up and the pics.
Old 09-02-2013, 08:21 PM
hriczko806's Avatar
hriczko806 hriczko806 is offline
Vehicle: 2004 Ram Quad Cab
Rep:91
hriczko806 will become famous soon enough
Ive done this. I mounted it right under the dash with a relay. I ran power to the relay and then from the relay to the fuse block. I ran switched power to the relay using the cigarette lighter. So the fuse block only comes on when the ignition is on. I also installed a ground block as well, just for the convenience.
Ive had this installed for almost a year with no issues. Good luck with the install.
Old 09-02-2013, 09:04 PM
I push the skinny pedal
Rep:3277
I've done this with both of my trucks. I mounted a piece of aluminum angle right next to the existing fuse panel and wired everything in. All my mods are wired into the fuse block so I can troubleshoot any issues as they arise.
I picked up a painless wiring CirKit fuse block, the one I have has 3 constant-on and 4 ignition on and has been a blessing when hooking up multiple devices.
http://www.painlessperformance.com/w...rchField=70207
Kurtis
Old 09-02-2013, 10:12 PM
ff6cav's Avatar
Color: Inferno Red
Rep:104
Glad to see I'm not the only one who's considered this In my research, I've come across some conflicting info on what gauge of wire to use to supply the fuse block- some say 4ga, some 8, 10, and so on. I've had trouble finding connectors and terminals for anything bigger than 10ga- in you guys' experience, would this be a safe size of wire to use?
"Little Red Wagon"
Old 09-02-2013, 10:38 PM
Rep:3277
your supply gauge wire is completely dependent on your power requirements. Since the fuse block you're looking at is a 12 circuit, and rated to 30amp per circuit, and if you're running all 12 AT 30 amp you'd be drawing 4,320 watts. An automotive rated 10ga wire less than 3ft will easily be able to dissipate enough heat without overheating due to voltage loss. If you're worried about it you can oversize the wire to 8ga, but it'd be overkill, especially since you won't be running all circuits at 30amp.
Kurtis
Old 09-03-2013, 10:18 AM
ff6cav's Avatar
Color: Inferno Red
Rep:104
Thanks!
"Little Red Wagon"
Old 09-09-2013, 04:32 PM
ff6cav's Avatar
Color: Inferno Red
Rep:104
Alrighty- the fuse box came in, installed beautifully, and everything worked great- until I went to start my truck, that is. Truck won't turn over, nothing comes on when I turn the key to the on position, and none of the switches attached to the fuse box work. I hooked up the battery charger, and it started right up immediately with no charge-up time; shut it off, and it won't do anything again. The fuse box has a relay and switch between it and the battery, so it shouldn't be draining power if the switch is off. I have no clue what may be the problem, and I'm planning on unhooking the main wires for the fuse box until I figure it out. Any thoughts or suggestions?
"Little Red Wagon"
