Old 09-06-2013, 11:01 PM
shektbg shektbg is offline
Vehicle: 2007 Dodge Ram 1500
shektbg is on a distinguished road
Question 3-5 Second Delay BEFORE Crank on Start?
My 2007 Dodge Ram 1500 has always started almost immediately when turning the ignition switch to Start (After waiting the obligatory second or two before turning for the Sentry security system to recognize the key). Recently, the truck has started having a delay between turning the key and the engine cranking. It began as a 2-3 second delay, and now can be 5, even 10 seconds before the starter cranks. No clicks, no noise, just nothing happens. Once the starter does crank, the engine fires up immediately.
I have had the battery checked, it's fine and nearly new. This doesnt have the symptoms of a battery problem. I have been doing some online searches, and I have seen several people report similar symptoms and have had responders suggest the Starter Relay may be bad, or Starter Solenoid. My understanding is that these are the same thing, correct?
Does anyone recognize this symptom and does it sound like it could be caused by a failing relay? That seems to be a much cheaper fix than replacing the starter itself, which I'm not convinced is the problem based on how nice it sounds when it does turn over.
Any suggestions are appreciated!
Old 09-10-2013, 07:42 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
Either you have a voltage drop from the battery + to the starter or your starter is starting to go out.
You would have to perform a voltage drop test on that cable to the starter and/or find somewhere to have the starter tested.
Start with the voltage drop test....ill post a video about it.
http://youtu.be/ry68G0C2Fyc
starting delay ignition
