Transmission Wont go into final gear - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-28-2013, 11:13 AM
Cyr220 Cyr220 is offline
Vehicle: 2000 Ram 1500 Club Cab 2wd
Color: Beige
Rep:17
Cyr220 is on a distinguished road
Default Transmission Wont go into final gear
Been driving my truck for a few months now and it seems like I can't get the Transmission to go into 5th gear unless i'm driving continuously for 45 minutes. I've heard of a temp sensor going bad but I can't seem to find it. Also anyone else that has dealt with this any advise would be helpful. Killing what little gas mileage I get.
Old 08-28-2013, 09:23 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Sooooo, engine coolant temp is normal? If your thermostat isn't working properly, that may be the deficiency which is simple enough a problem to rectify. That's all I know of that problem, sorry!
Old 08-28-2013, 09:26 PM
Rep:2954
sorry, i can't help you, but someone else may have had the same issue
Old 08-28-2013, 11:22 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Battery showing a full charge when you first crank it up? R...
Old 08-30-2013, 10:34 AM
Color: Beige
Rep:17
Levels are good on coolants and oils. Battery is charged up fine. Everything works perfect until I get to 4th gear then it stays in gear and won't go into 5th or "lockout" if I feather the gas.
Old 08-30-2013, 10:49 AM
HammerRammer HammerRammer is offline
Vehicle: 2013 Dodge Ram 1500
HammerRammer is on a distinguished road
I'm thinking maybe a splitter problem...
Here's some other suggestions here:
http://www.ehow.com/how_5357959_diag...-problems.html
Old 08-30-2013, 11:00 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Does your truck have a towing mode?
Old 08-30-2013, 01:42 PM
Color: Beige
Rep:17
Not that I know of the only thing that looks like it would have anything to do with towing is the tranny cooler but thats it.
Old 08-30-2013, 03:01 PM
anothernewb's Avatar
anothernewb anothernewb is offline
Vehicle: 2013 Laramie Crew Cab
Color: Dark Cherry
Rep:168
anothernewb has a spectacular aura aboutanothernewb has a spectacular aura about
I had a similar issue with my jeep once. it wouldn't go into OD one winter. I was told that it's a temperature thing, the trans won't go into higher gears until it warms up to the correct temp. But like you, there's a trans temp sensor, but it didn't seem to affect anything.
I don't know if this helps, but I was able to trace the issue back to the TPS of all things. it was giving readings that were out of spec somehow and perhaps it was tricking the trans into thinking it the throttle was stepped down or something?
Since it got fixed simply, I never dug into it too much, but like your situation, it took forever for the trans to work "normally" my guess is that something was corroded in the sensor and it wasn't until the engine bay built enough heat up that it worked right.
Livin life one truck payment at a time.
Old 08-31-2013, 01:47 PM
Rep:177
RogerRamJet asked you if it had tow mode. At the end of your Shift handle on an automatic there's a button in the center on the end knob (push it in and on the dash you should see OD off). Your over drive could be acting up. R...
