Old 10-13-2013, 03:43 PM
star gezzer star gezzer is offline
Vehicle: 2001 dodge 2wd diesel
star gezzer is on a distinguished road
Unhappy Front hubs 2500 2wd
I am replacing the front bearings on my 01 2500 2wd diesel. I can't find any information on the tightening procedure for replacing the hubs, they are using a self locking nut and I am not sure if the procedure is to use a preset torque limit or tighten to contact and then add 1/4 or 1/2 turn or???? none of the cheap repair manuals even address replacing the hubs.
Need help soon:
Thanx
Old 10-13-2013, 07:54 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Tighten it by hand, then give it another half to 3/4 turn. Put the cotter pin in and call it a day.
Old 10-14-2013, 10:20 AM
This is a 2wd 2500 and used a self locking nut the spindle has no keyway or hole for a cotter pin.
Old 10-14-2013, 11:40 AM
God Bless Texas!
Rep:2929
OK then, my best guess would be the same principle, however you can't hand tighten it. I'm gonna have to go with calling your shop or look in a service manual to get the proper torque specs. I could guess, but that would not be very good considering it's your front wheel that's being tightened down. If I were doing it, I would be comfortable with what I did, but I can't tell you to do the same.
OK, so I looked on a couple other forums, and the consensus is 180 ft. pounds for the axle nut. Whether or not that is correct, I don't know.
Old 10-14-2013, 07:53 PM
I have checked with a couple of truck shops and a Dodge service center, and they can't make up their mind. I'm getting answers from 80 to 280 ft. lbs. so it looks like we're all on our own.
But thanks anyway!
Old 10-14-2013, 11:20 PM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
Copied of the dealer install.
On models with all-wheel antilock system (ABS), check condition of tone wheel on hub/bearing. If teeth on wheel are damaged, hub/bearing assembly will have to be replaced (tone wheel is not serviced separately).
Slide the hub/bearing onto the spindle.On 3500 HD slide the spindle stub shaft into the hub/bearing and tighten.
Install the new hub/bearing nut and tighten to:
LD 1500: 251Nm (185 ft. lbs.)
HD 2500/3500: 380 Nm (280 ft lbs.)
Install the rotor onto hub/bearing wheel studs.
Old 10-14-2013, 11:24 PM
Howells's Avatar
Rep:19
4wd is 180 ft/lbs and uses a cotter pin.
Old 10-18-2013, 03:40 AM
Pacheco911 Pacheco911 is offline
Vehicle: 1998 Dodge Ram 1500
Color: Dark Green
Pacheco911 is on a distinguished road
I know on older dodges the locking nut had tabs that you hit down to keep them from coming loose.
