Best tire size? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-29-2013, 03:25 AM
dodgeram02's Avatar
dodgeram02 dodgeram02 is offline
Vehicle: 2011 Dodge Ram 1500 Quad Cab
Rep:59
dodgeram02 will become famous soon enough
Default Best tire size?
ok i'm getting ready to get new tires. but am getting told 400 things from 400 people. I have 275 60 r20 now. with a daystar leveling kit. going to be using stock rims. I want to go as big as I can using this setup. I have been told these tires are a 33 x11.4. the dealership told me to go with a 285/70 or 285/75. guy at goodyear said 275/65 or 305/60 or 35x12.5.
went and seen a 285 70 and it looked similar to the size I have. and the 35 x12.5 looked like it would rub. also heard not to go over a 12 inch tire on stock rim. hoping somebody can help me. or point me in right direction. please and thank you.
"I dont lie to my wife about my truck...I dont lie to my truck about my wife, they both know, no matter how good they treat me I'm still going to get on the other one"
Old 08-29-2013, 07:21 AM
dsuv59rt dsuv59rt is offline
dsuv59rt is on a distinguished road
try looking into a 305/55/20 same height but wider.
http://www.miata.net/garage/tirecalc.html
here is a tire size calculator. pretty accurate
Old 08-29-2013, 09:59 AM
Vehicle: 2010 Ram RCSB 4x4
Rep:561
I depends which 20" wheel you have, and whether you have a 2WD or 4WD
Sport/Laramie Chrome Clad's are 20"x 9"
Painted Aluminum 20's are 20" x 8"
Not all tires labelled as a "305" are the same width, you have to go to each manufactures website
to see how wide the tire actually is when mounted on a suggested rim size.
For example:
a 305/50R20 Terra Grappler on a 9" wheel is 12.2" x 32.2"
I have those on my 10' RCSB 4x4 (20"x9" Clad Sport Wheel +19.05 offset)
Just one size up, a 305/55R20 is 12.4" wide x 33.19" tall and rubs
If you go to that same size in an LT (10ply) it's 12.6" wide x 33.07" tall (also rubs)
all three list rim width of 8.5 minimum (9.5 recommended)
My 305/50R20 clears the upper ball joint on the control arm by less than 1/4" so it works for my 4x4
(even though its lowered 2/3)
I have heard 2WD Rams are getting rub issues at full turn lock trying to run that same tire on the same wheel
I would say stay away from any tire over 12.2" wide
(based on a stock 20" chrome clad wheel)
I've heard many have successfully mounted 295/60R20 Trail Grappler on Painted 20's (8" wheel)
with a level kit up front, no issues
The tire is 12.13" wide x 34.45" tall on a min rim width of 8", 8.5" recommended
Old 08-29-2013, 10:55 AM
dodgeram02's Avatar
Rep:59
its the chrome rims. was told they was 20x9 and the truck is 4wd.im going to go with a goodyear duratrec or a goodyear mtr with Kevlar. I was told told the tires I have now are 33x10.8 if that's true I would like to go about 11.5 to 12 inches wide and as tall as I can.
Old 08-29-2013, 11:11 AM
Rep:561
For an MT/R with Kevlar, you need to go up to an LT series
Keep in mind, that's a HD tire (E load rated) weighs 63 pounds without rim
(stock 275/60R20's are about 42lbs)
LT285/65R20 is 11.5" wide x 34.8" tall would be perfect size for your setup (4x4 with level kit)
the only other option for a 20" wheel is a 33"x12.5" (too wide at 12.5", and shorter 32.8")
or a 35"x12.5" (12.5" wide x 34.8") the width would likely be a rub issue on stock wheels
http://www.tirerack.com/tires/tires....MTRK&tab=Sizes
For a Dura Trac your options are
LT275/65R20 ( 11" x 34.1" )
LT285/60R20 ( 11.5" x 33.5")
LT305/55R20 (12.4" x 33.2") will likely rub
LT325/60R20 (13" x 35.4") will definitely rub
souce:
http://www.tirerack.com/tires/tires....ngler+DuraTrac
Old 08-29-2013, 11:38 AM
I know what you mean by manufactures, i run the coopers 305/55/20 on my 2011 sport crew 4X4. 20X9 wheels, with no issues what so ever, you do bring up a good point. thats why i added a tire size calculator most tires are with in a few mm and the calculator is a good starting point so he can compare tire sizes side by side....
Old 08-29-2013, 02:40 PM
dodgeram02's Avatar
Rep:59
the dealership told me to go with 285/75/20. or 285 70 20. what size would the tires be. I went to a size comparison site and it says the 285 75 is like a 36.8 height.
Old 08-29-2013, 02:57 PM
Gantman's Avatar
Gantman Gantman is offline
Vehicle: 2016RCLB4x4/44-45
Trim Level: Tradesman w/3.92 LSD
Rep:999
35.71" tall on those 285/70-20's and you are correct in the 285/75-20 at 36.83" tall. Both are 11.2" wide.
Total Chaos UCA's, Fox 2.0 IFP Coilovers and shocks, TTC-1223V variable rate coil springs.(Mods list)
Old 08-29-2013, 04:38 PM
hodge's Avatar
hodge hodge is offline
Vehicle: 2011 Dodge Ram Sport
Rep:26
hodge is on a distinguished road
I am running 296/65/20 trail grapplers which according to the nitto site are 35.47 x 12.13. I have no issues, but am running 1/4 inch spacers. not sure if they would rub the control arm or not without spacers. I'd go with the 285/70/20 if you want the tallest tire possible, pretty sure you'd clear them and since they're skinny you wouldn't need any wheel spacers.
RCX 2.5" level - 1.5" Zone Body Lift - 295/65/20 Trail Grapplers - 20x10 Moto Metal 970 - Debadged - 18" Magnaflow and Y-Pipe - S&B CAI - DiabloSport Intune DCX
Old 08-29-2013, 05:18 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
+1 to Blackramhemi............
sales@revelperformance.com
