Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 08-29-2013, 09:19 PM
Codesman's Avatar
Codesman Codesman is offline
Vehicle: 2012 2500 crew cab
Color: Mineral Gray
Codesman is on a distinguished road
They need to do what they did on the new chargers. The oil filter is on the top of the engine and is the cartridge type. Easy to change and no spilling.
Old 08-29-2013, 10:33 PM
Grubrunner's Avatar
Rep:3883
We should count ourselves lucky. Some cars require removing components [skid plates with Torx bolts] just to access the engine oil filter and some will have your hand/arms looking like you just walked out of a bar brawl. Read: 1999 Honda Civic, 1985 Honda Accord and 1998 Toyota Supra come to immediate mind.
The top mounted engine oil filter is a common Subaru thing of late and older BMW's did it too, but I have NFC why.... ? I'm sure there are others.
Must be a ground clearance issue or maybe just an ease of access thing.... dunno'.
Personally - and as long as they're not a major PITA and you don't need the arm/hand width of a 5YR old - I'm a fan of bottom mounted oil filters for the most part. You're killing two birds with a single stone while changing your oil too whilst under there. I also like the pre-fill feature of bottom mounted oil filters with a top-facing mouth. Trying doing that with a top mounted oil filter with a bottom-facing mouth.
Not gonna' be pretty....
Grub out!
Old 08-29-2013, 10:40 PM
Hermes1 Hermes1 is offline
Vehicle: 2015 Big Horn 3500 Cummins TD
Rep:2559
Good point and yes things could be worse.
Old 08-29-2013, 11:04 PM
RPM666's Avatar
RPM666 RPM666 is offline
Vehicle: 2012 RAM 1500 LL Limited 4x4
Color: True Blue
Rep:363
RPM666 is just really niceRPM666 is just really niceRPM666 is just really niceRPM666 is just really nice
Paper plate with high ridges. Put some tape on the underside to stick it in place, then unscrew the filter and place it on the paper. After a minute or so put the new filter in place and carefully remove the old filter and paper plate.
I change my oil without spilling a drop.
**I have also changed my oil and forgot to put the oil catch under the pan when I got the drain plug out - so ya know, it's a learning experience through life
S&B CAI // Flowmaster 50 Series HD // Bilstein 5100's @ 2.8" // Lockpick V5 // Hypertech Interceptor // Cabin filter mod // BP Polished Catch Can // TonnoPro LoRoll Cover // 4 Digit Combo Console Vault // Escort 8500 X50 Blue // GumCreek Vehicle Holster
Old 08-29-2013, 11:51 PM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
DOH! Betcha won't do that again.
Old 09-02-2013, 09:53 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
A Kroger ice cream 1/2 gallon bucket works perfect. Put a couple paper towels in bottom of bucket to keep splashing down, let filter sit in bucket as the rest of oil drains from oil filter housing. Bucket sits on top of rack and leans against frame rail.
Works perfect with no mess or oil on your hands.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 09-05-2013, 09:23 AM
BigT BigT is offline
Vehicle: 2014 Ram 1500
Trim Level: Limited
BigT is on a distinguished road
I go to Jiffy Lube. With their coupons it doesn't cost much more than buying 7 quarts and a filter myself and dealing with the hassle. I used to change the oil on all my vehicles but it go to be a PITA. I did have a car with the filter in the hood so I used a MityVac to suck the oil out through the dip stick. That might work on a Ram to avoid such a mess when removing the filter. It comes in handy when changing the oil on my lawnmower, snowblower, etc so might be worth the investment. I think they're like 50 bucks.
Old 09-05-2013, 01:01 PM
05 bee 05 bee is offline
Color: Deep water blue/light sandstone
05 bee is on a distinguished road
Punch a hole in the bottom with an awl use an old coffee cup stick it on the filter and spin it off
Old 09-05-2013, 03:42 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
You could also punch a small hole in the bottom of the filter first with a punch or screwdriver, just be ready for it, then you can bag it after most of the oil flows out.
Old 09-10-2013, 01:09 PM
rsg1963's Avatar
rsg1963 rsg1963 is offline
Vehicle: 2006 RAM 3500; 2010 RAM 1500
Color: Black 2 tone grey
Rep:48
rsg1963 is on a distinguished road
+1 on the baggie deal. I learned it changing the oil on my Cummins. Double gallon sized for that filter. For the Hemi a standard sized, freezer thickness ziplock will do. But be sure the oil has cooled a bit. I have had it leak right out of the bottom when I removed the filter immediately following shut down. (Yes, I laughed at the time because it was so stupid of me ) It's not really the heat alone, but the heat combined with the weight of the filter.
RAM Pickup: 2010 1500 Laramie Hemi: Magtec Rear Diff cover/AmsOil 75w-110 Syn, 24" Magnaflow, Resonator delete, Line-X; Bilstein shocks with leveling kit 2.75";305/60-20 GY Wrangler Silent Armor Pro Grades; Lift Air Bag Suspension;
RAM Truck: 2006 3500 ST Cummins:Line-X; Leveling Kit 2" with Edelbrock shocks; Ultra Custom rims w/ 265/70-17 Goodyear Silent Armor Pro Grade; Backup Camera/NAV/DVD video/Reese 24K 5th wheel hitch; RDS 51 Gal tank/toolbox; Banks:CAI, MonsterRam 3.5",Monster Exhaust;Pac Brake Prxb.
