Old 08-29-2013, 06:31 PM
Tongan Built's Avatar
Tongan Built Tongan Built is offline
Vehicle: 2011 Dodge Ram
Color: Stone White
Tongan Built is on a distinguished road
Default bad mpg after spark plug change
i changed my spark plugs at 42000 should've been at 30000....the stock ones are ngks and they swap it out with champions....i wonder why and wonder if thats the cause. my air filter is brand new as well. anyone have same issue?
Old 08-29-2013, 06:39 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:221
If you got the coils back on correctly and gapped them correctly, it shouldn't have hurt your mileage. Did you put any special plugs in or are they just plain Champion copper plugs. I've heard of people having problems with plantinum and the high dollar plugs, but not with just regular plugs.
Also, how do you know your mpg is worse? Single tank? I guess I'm saying are you for sure you mileage is worse, or is it something else.
Old 08-29-2013, 08:08 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Yes make sure to use oem plugs, or iridium. Don't buy in to the hype of all these magical plugs, they are pretty much all worse that oem as far as performance and efficiency. You want an oem copper(or iridium) single ground electrode plug.
Sean
Old 08-29-2013, 11:03 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Put some $1.99 Champion OEM plugs in last week. Getting 2+ more mpg after the switch. Added synthetic oil, too. But I'm thinking the plugs are where the real gain is.
Old 08-30-2013, 09:57 AM
4Play1 4Play1 is offline
Vehicle: 2011 CC Sport
4Play1 is on a distinguished road
When I had my 2003 Hemi I had the dealer change mine at 30k. This was the worst decision ever. My MPG's drop a lot also. I do not plan on driven this truck forever so I will not be doing the plugs. From my understanding the plugs will last 100k but the problem is they my seize.
Old 08-30-2013, 12:38 PM
HammerRammer HammerRammer is offline
Vehicle: 2013 Dodge Ram 1500
HammerRammer is on a distinguished road
I would pull them out and re-gap them...that's only thing that could cause problems if it's directly related to the spark plug change. Unless they're just the wrong ones.
Old 09-03-2013, 02:34 AM
Trim Level: sport
Color: green
Rep:643
any improvement in the mileage yet?
Old 09-07-2013, 03:10 PM
Color: Stone White
splzfr5c11...this is the plugs they put in....im not good with my hands on cars, so i just had the dealer do them...im plannin on goin back to dealership nx week to have them double check if they were done properly spaced out correctly and all those things you guys mentioned, thanks! however on a side note i wonder if its the tire psi...i noticed they pump it to 35 as recommended but i use to get 44 psi all the time, this is the first time i got 35psi in my tires when they changed my plugs, wonder if that had an mpg effect.
Old 09-07-2013, 03:12 PM
Color: Stone White
u know whats also funny the model plugs (oem) i posted...the ones they installed said nickel plugs on the box but everyone says the stocks are copper? wonder why they put nickel plugs in
Old 09-07-2013, 04:33 PM
snrusnak's Avatar
Rep:1385
I don't believe that's an oem plug.
Sean
