MOPAR DECALS
Old 09-12-2013, 11:23 PM
ArmyofOne's Avatar
US Army Retired
Color: Blue Streak Metallic
Rep:1230
Put some $1.99 Champion OEM plugs in last week. Getting 2+ more mpg after the switch. Added synthetic oil, too. But I'm thinking the plugs are where the real gain is.
Actually synthetic is likely where your gain came from. I can't explain why or how, but EVERY motor I have ever switched has seen at least a 1-2mpg increase on average. EVERY one. Not here or there, hit or miss, consistently. 14 motor's over the last 8 years or so. (had a lot of cars LOL)
Originally Posted by 11silverslt View Post
I just changed my plugs today, bought them from the dealer and they were Bosch plugs in Mopar boxes. All was going well until the coil boot was seized on the rear most plug on the driver side of the engine, well we all know what that means a trip to the dealer for a replacement coil, because no parts store stocks coils for my 4.7l engine. Had to go to two different dealers and bought two just in case. Good thing because I broke another one finishing up. While at the dealer a tech said they change the plugs when the motor is real hot to avoid the boots seizing onto the plugs. Truck runs good now with al the new plugs and air filter and coils and it only cost me $ 147.01 for a tune up and all day Saturday running around. Don't know about the mileage yet but I was getting 18 + on the highway before so we will see.
I would not let that tech or anyone from that dealer anywhere near my truck...EVER.
Pulling the plugs on a hot engine is a good way to pull the threads out of an aluminium head. Metal expands and contracts with heat/cold. Since Alumnium dissipates heat faster than most other metals (including the ones your plug's threads are made of), they expand at a MUCH slower rate than the plugs. So the plug threads are expanded while the heads threads are not expanded as much. Removing a plug at that point will almost certainly strip the threads in the head.
When that happens, sometimes you get lucky and there are a few threads left that can hold the plug in place, but then there are metal shavings in the engine. If you are unlucky, the head has to come off to be re-tapped.
COMBAT WOUNDED VETERAN
-2015 Ram 1500 Laramie Crew Cab 4x4. Lifted, Modded, Attitude.
2002 Lexus ES300. My Daily.
2014 Civic EX. Wifey
2008 Corvette Pace Car Convertible. #325/500
Old 09-12-2013, 11:37 PM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Really? That's good to know. Really didn't care where it came from, just glad it's there. Thanks for the info, Josh!
