installing hemifever tune issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-29-2013, 09:43 PM
brondondolon's Avatar
brondondolon brondondolon is offline
Vehicle: 2009 Dodge Ram 5.7L hemi
Trim Level: 1500
Rep:177
brondondolon has a spectacular aura aboutbrondondolon has a spectacular aura about
Default installing hemifever tune issue
so Sean at hemifever sent me the tune for my diablo intune. he asked for me to change some things in my PID but im not to familure with the tuner so I think I may have messed up. this is what he requested.
Ignition : spk adv 1
Miscellaneous : P-Ratio Map, Desired FA Cyl1
Misfire : KNK ST Retard, knock sensor 1 and 2 volts
Performance : Vehicle speed and engine rpm
Intune : As far as the steps, scan tool, click yes, datalogging, configure, pid select, add in the additional PIDs that you requested,when done adding click back button, then click record.
when I went through the steps I couldn't find the exact requests. Does any one have any better instructions?
thanks guys
S&B CAI, Y-pipe muffler delete, Diablo intune, Hemifever, custom tune, 180 thermostat, BT oil catch can, smoked, tail light and 3rd breaklight, 5000k retrosolutions 55w HID headlights and fog lights, LED in all exterior lamps, red calipers. Future mods: 87mm TB, 3000 stall torque converter
Old 08-30-2013, 10:44 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
can the intune hook up to a laptop like the predator can? I find I can datalog easier and pick the pids easier this way..
Old 08-30-2013, 02:31 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Yes you can view data logs the same way with the Intune.
Plug your Intune into your computer. Find the InTune Comp User Manual PDF. It will explain logging within it.
See Section 4.4
It's a truck, not a cream puff
Old 08-31-2013, 12:22 PM
Trim Level: 1500
Rep:177
i got everything worked out. thank you guys. my transmission has been acting funny since i installed the diablo and now its a little worse since i installed the custom tune. should i be concerned or is this initial normal behavior? what it does is some times it feels like its really trying to catch the gear in a jerking way. or kinda like the tires are breaking loose and the traction control is kicking in. i dont think the tires are breaking loose though because this normally happens in like 4th or 3rd gear when i floor it and i dont think ive gained THAT much power as much as i wish was the case lol.
Old 08-31-2013, 01:46 PM
06 BigHorn's Avatar
Rep:153
Contact Sean would be my first thought. The computer learns your driving habits, give it a few days to settle down
