Old 08-14-2013, 12:27 PM
DamRam DamRam is offline
Trim Level: Lone Star
Color: Gray
DamRam is on a distinguished road
Default x or h pipe?
I've heard that doing an x or h pipe does wonders for your exhaust setup. I've been thinking on doing one of these but just not sure which one. Is anyone running one of these setups and if so how do you like it? Do they make it any louder? I'm running BBK headers and cherry bomb extreme mufflers and if I do one of these setups will it make it ever louder? Thanks for the help
Old 08-14-2013, 12:31 PM
Rep:1385
There won't be much of a difference between a good x, h, and y pipe setup. So most go with a y pipe because it's significantly cheaper. But any would work well.
Old 08-14-2013, 12:54 PM
Rep:2117
I'm assuming you're running a true dual set up?
If so then yes, you want either an X pipe or a H pipe. There has been many posts on this subject throughout the forum. There is a particularly good one by Grubrunner explaining the differences between an X and H pipe. That post is definitely worth finding.
To sum it up. An X pipe gives you better flow by scavenging exhaust from either side of the system. An H pipe equalizes the pressure between both sides of the system to allow better flow.
Old 08-15-2013, 01:31 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
if you already have true duals an H is really easy to do for any exhaust shop...
Old 08-19-2013, 05:06 PM
FeedMetal's Avatar
FeedMetal FeedMetal is offline
Color: Maximum Steel Metallic
Rep:83
FeedMetal will become famous soon enough
http://youtu.be/Y0Va3sDhqwI
this should help ^^^^^^^^^^^
'13 Sport Crew Cab / Hemi / 6-Speed / 3.55 / Anti-Spin - aFe Stage II CAI - MF 14" Muffler - BP 87mm TB - BP Catch Can
Old 08-24-2013, 02:17 PM
RAMinator13's Avatar
RAMinator13 RAMinator13 is offline
Vehicle: 2013 ram crew cab Sport 4x4
Trim Level: Sport/laramie
Color: Black beauty
Rep:43
RAMinator13 is on a distinguished road
So would a x pipe or h pipe givw me better torque on my 2013 cc with true dual 2.5 with super 10's
2013 RAM CC Sport 4x4 - 6spd 3.55 Anti-spin diff. MODS: 35x12.5r20 Mickey Thompson Baja ATZ - Rough Country Level 2.5 front & 1.5 rear - Airaid MXP Cold Air - Magnaflow Magnapack 4x14 & Magnaflow True Flow Y pipe mod- 20x9 Ballistic Razorbacks
Old 09-01-2013, 10:34 AM
FeedMetal's Avatar
Rep:83
i would but a X or H, just to even out the flow between the two banks, will also improve flow and sound.
for best results put the X or H pipe as close to the cats/manifolds as you can, better flow. (around where the old Y-pipe use to be)
Old 09-01-2013, 11:59 AM
Lake O Hunter Lake O Hunter is offline
Vehicle: 2004 Dodge Ram 1500 QC 4x4
Color: Gray
Lake O Hunter is on a distinguished road
I went with pacesetter mid length headers and a magna flow x-pipe muffler; it has great sound and saves space from having to install x-pipe and mufflers.
