Old 02-21-2014, 05:40 PM
monte07 monte07 is offline
Vehicle: 2013 Ram 1500 RCSB
Color: Gray
monte07 is on a distinguished road
Thumbs up Cool
Nice work. Your truck looks awesome...
Old 02-22-2014, 01:19 AM
DarthRam's Avatar
DarthRam DarthRam is offline
Join the Dark Ram Side!
Rep:1543
Thank you. Much appreciated.
Old 02-25-2014, 10:33 PM
DarthRam's Avatar
Rep:1543
So, I got a new Dremel. So, I had some mods set aside. So, I did some mods. Since it is still winter I couldn't go all out and actually put them on the truck. Here is what I did:
I taped off around the area I was going to cut to make sure I didn't mark up anything I wanted to keep. I used a cutting wheel instead of the cutting bit as it seemed to create less residue. I left the center piece connected to create more area for the adhesive as well as structure.
The custom badges aren't permanently attached yet for two reasons:
1) I still need to trim the covers to fit the Ram 5.7 as they are for a Charger.
2) I am not 100% sure what I should use to keep these permanently attached. Do I use 3M tape? Do I use Gorilla Glue? What can I use that will adhere plastic to plastic and be able to withstand the heat and cold of the engine bay?
I did this on my dining room table. Yes, I live alone. Weird huh? Anyway, I had the Dremel in my right hand and the vacuum hose in the other. The valve covers have rubber boots that sit on posts on the engine. These work perfectly in holding the cover from moving around while I was cutting. On one side anyway. The other side I probably should have clamped it down but it wasn't that bad actually. I highly recommend taping around your work area. The Dremel kicked a couple of times and ran across the tape. In the end I used my knife to get rid of the burrs around the cuts. This worked quicker and cleaner then using a grinding wheel or cone. Now that I see these pics I might just mask the chrome lines on the top and paint them white.
I cut the lettering out over just grinding them down for less mess and quickness. I think it turned out pretty well.
Old 02-26-2014, 11:16 AM
RogerRamJet's Avatar
I do it because I can!
Vehicle: 2005 RAM 1500
Trim Level: LoneStar QC
Rep:2945
Pretty well? Dood, you're a masterba.... hang on a minute. That's gonna sound funny, and not in the ha ha way. Let's just say you've got talent. Nicely done, Dave!
Old 02-26-2014, 08:54 PM
Wizar Wizar is offline
Vehicle: 2012 Ram
Wizar is on a distinguished road
I've always loved the punisher skull icon, not sure if that was what you were going for but i LOVE the truck...keep up the good work!!!
Old 03-11-2014, 12:29 AM
DarthRam's Avatar
Rep:1543
It was EXACTLY what i was going for!
Old 03-11-2014, 12:31 AM
DarthRam's Avatar
Rep:1543
Very small update. Got my new lugs on today. Check here for the whole story:
http://www.ramforumz.com/showthread.php?t=169320
Before:
After:
Subtle difference but these won't rust.
Old 03-11-2014, 09:00 AM
Rep:2945
Every little bit helps.
Old 03-11-2014, 09:12 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
very nice!
Old 03-12-2014, 07:55 PM
fire50's Avatar
fire50 fire50 is offline
Vehicle: 2014 Ram 2500
fire50 is on a distinguished road
Wheel and tire combo looks awesome!
mod build sport 2013 quad
