2001 ram 1500 5.9 will not start - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-30-2013, 07:40 AM
Justinram1500 Justinram1500 is offline
Vehicle: Ram 1500 2001 dodge
Justinram1500 is on a distinguished road
Default 2001 ram 1500 5.9 will not start
Have a 2001 ram 1500 5.9 sport package 4x4 auto had the truck for 1 week and Has not ran right since put new PCM and new crankshaft sensor along with put another camshaft sensor off of another truck if you let it sit up for a day or so it will start and run perfect but then will die out of no where and will NOT start back unless you hold the gas flat on the floor and it takes forever to start back almost likes its flooded because you can smell gas strong then runs HORIBLE will not idle and runs extremely rich black smoke I've took the throttle body off and cleaned it nothin has helped can somebody please help ??????? thanks in advance
Old 09-01-2013, 12:16 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
And the fuel pressure is? No, seriously, check it, long term, stick the gauge under the wiper, you want to know the PSI WHEN its running bad, if the PSI goes down, its a pump35 and steady is good. There is no filter in the system, so that ain't the problem, unless someone added one inline somewhere. Good Luck.
