This seems odd.... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 09-02-2013, 08:52 PM
NightStalker NightStalker is offline
Rep:34
NightStalker is on a distinguished road
Default This seems odd....
I tried to plug my Iphone inyo my AC outlet and it did nothing. So, I thought I'd look under the dash to see if I could check the fuse box for a blown fuse...... well, I stopped my search when I found all of these loose wires
I just bought this used 2010 last week from a reputable dealer, and it allegedly passed a comprehensive inspection. Do all these loose wires seem right? What am I missing?
NS
Old 09-02-2013, 09:42 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1125
I haven't got my truck right now to compare. But I would attach anything that fits together and see what happens. If you're not sure, you can take it back to your dealer and show them and get them to sort it.
285/65/20 BFG TA KO2s, Bilstein 5100s, Solid Fold tonneau, Rhino Liner, Husky Weatherbeaters, Magnaflow 18 muffler, Mufflex 5" tips, Carbon wrapped interior trim, Chime delete, Britax baby seat...
Old 09-03-2013, 03:20 PM
dodge man's Avatar
dodge man dodge man is offline
Vehicle: 2004 Quad Cab diesel
Rep:235
dodge man has a spectacular aura aboutdodge man has a spectacular aura aboutdodge man has a spectacular aura about
Man, I'd haul the thing to the crusher right now! I'm actually joking. I can't say for sure on your truck, but what you see is pretty common. For example the black thing in the upper left of your photo is for the OBD, which normally wouldn't have anything plugged in. Maybe another plug in is for a heated steering wheel, which you don't have etc. They usually put in a wiring harness for every available option and if you don't have them, there is a wire harness hanging where it would plug in.
2004 3/4 ton Quad Cab, 24 valve 5.9 Cummins
Old 09-03-2013, 03:48 PM
Rep:2929
NightStalker
may i suggest that you finish filling in the USER CP / EDIT YOUR DETAILS / VEHICLE section, it makes it easier for other members to know what year/model/etc.
that you are driving & asking questions about
as for your Apple ( & some others ) device
look in your upper glove compartment, the bulkhead closest to the radio
i believe that you will see a MINI USB port that you can connect your device into
by the way, which radio do you have
the 3 letters that identify the radio, can be seen on the face of the radio, near the auxiliary port, lower right corner
they could be:
RHR, RER, RHB, RBZ, REN, RES with the phone button hard key, or RES w/o the phone button hard key
Please let us know what you find
Old 09-03-2013, 04:12 PM
Rep:34
GTYankee: Sir, I sent you my VIN numbers late last week via email. If they did not make it to you, please let me know and I will resend. I still do not know with any real certainty which model I truly have.
It does not appear that I have the USB in the glove box (see pic below):
It looks like I have the "RES" model radio.
What is odd to me, is that this radio has all the "buttons for the hands-free (UConnect) set-up, but when I tried to synch my Iphone it showed me this message (pic below):
If I wanted to get the Uconnect system/capability for my Ram, do I need to replace the radio? If so- which I am certainly not opposed to- which radio should I pick-up, and will it be an easy swap?
Thanks in advance for your time and assistance with these issues..... you guys are a TREMENDOUS help!!
NS
Old 09-03-2013, 04:25 PM
Rep:34
Dodge Man:
Good point. I contacted the dealer and they are going to take a look at it Thursday morning.
They are a GMC/Buick Dealer, so if the head scratching becomes unbearable I'll share your information with them....... after they sweat it out for a bit.
Thanks again for the assist.
NS
Old 09-04-2013, 01:56 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
You said you were trying to plug into the AC outlet. So you mean to charge the phone .....right? To turn on the AC outlet you have to hit the button on the dash that looks like (ll).
Otherwise if your trying to hear music out of your iphone you need a 3.5mm male to 3.5mm male headphone jack and plug that from your iphone to the AUX input on your radio.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 09-04-2013, 08:34 AM
Rep:34
LeftCoast:
Roger, I was only trying to charge my Iphone (not listen to Pandora, etc...). I plugged in the phone and hit the power button and didn't get anything.
What I found out this morning is that I might have a bad Apple charging "block", and not a problem with my external power source in my Ram. I'm headed out for a short run and when I return, I'll get to the bottom of this!!!
Thanks for the help.
NS
Old 09-05-2013, 08:56 AM
JohnnyDollar's Avatar
JohnnyDollar JohnnyDollar is offline
Vehicle: 2012 Ram 1500 Quad Cab
Trim Level: Lonestar
Rep:233
JohnnyDollar has a spectacular aura aboutJohnnyDollar has a spectacular aura aboutJohnnyDollar has a spectacular aura about
Originally Posted by NightStalker View Post
<snip>
NS
I am not an expert, but I have the same radio (RES) in my 2012; however,
I do have the voice command and UConnect features.
My understanding is that the UConnect is a separate module which plugs into the rear of the radio, so you will probably just have to buy the module and plug it in.
You may have to go to a Dodge dealer to have vehicle computer flashed to let it know you now have the UConnect module to activate the features, but I am not sure on that.
Another piece of good news, I think the USB port for the glovebox is also part of the UConnect module.
or it may already be tucked up in the wiring and simply not installed.
I am a little confused why you emailed your VIN to the website.
As mentioned by GTyankee, I simply filled out my vehicle information in the User CP when I registered.
2012 Ram 1500 QC Lonestar Edition - La Bestia Defavorable
Old 09-05-2013, 09:59 PM
Rep:34
JohnnyDollar:
Thanks for the advice. I think I am gonna dig around the RamForumz to find out how difficult it is to just do a radio swap. I don't need the navigation, but I would like to have the hands free, and bluetooth capability.
I sent my VIN to GTYankee because he offered to help me decode my truck right after I bought it. I was able to send the VIN and all of my purchase info to Dodge to get the print-out of my build sheet.
I am still unsure which model I have. I think it is a Ram 1500 SLT Quad-Cab Sport.... but I don't know.
Here's the build list:
*GJ Leather Trimmed Bucket Seats
-DV Dark Slate
ADAP Luxury Group
AGGP Sport Group
AJB Remote Start and Security Group
APAS Monotone Paint
BABS 160 Amp Alternator
BCVS 700 Amp Maintenance Free Battery
BNBS Electronic Stability Control
BRTS Anti-Lock 4-Wheel Disc Brakes
CACP Bucket Seats
CBWP Highline Door Trim Panel
CGDS Front Height Adjust Shoulder Belts
CGSS Supplemental Side Air Bags
CG3S Advanced Multistage Front Air Bags**
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKES Carpet Floor Covering
CLES Front & Rear Floor Mats
CSPS Driver/Passenger Assist Handles
CSXP Rear 60/40 Split Folding Seat
CUES Rear Underseat Compartment Storage
CVNP Folding Flat Load Floor Storage
CV2P Overhead Console w/Garage Dr Opener
CV3P Urethane Shift Knob
DBAC All Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHSP Floor Mount Automatic Shift Lever
DH5S Elec Shift-on-the-Fly P/Time T/Case
DJMS 205MM HD Front Axle
DMDS 3.55 Rear Axle Ratio
DRBS Corporate 9.25 LD Rear Axle
DS7S Conventional Differential Frt Axle
DS8S Conventional Differential Rear Axle
EZH 5.7L V8 HEMI MDS VVT Engine
GACS Tinted Glass Windows
GFES Rear Power Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GNZP Auto Dim Exterior Mirrors
GT5P Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GXMS Remote Keyless Entry with All-Secure
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGBS Dash Liner Insulation
HGFS Floor Tunnel Insulation
JATS Instrument Cluster w/Display Screen
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JFJS Temperature & Compass Gauge
JHAS Var Intermittent Windshield Wipers
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JKVP 115V Auxiliary Power Outlet
JKYS Power Accessory Delay
JPBS Power Locks
JPWP Power Lumbar Adjust
JP3S Pwr Front Windows, 1-Touch,Up & Down
JRTP Power 10-Way Driver Seat
LAZS Vehicle Information Center
LBCP Glove Box Lamp
LBDP Ash Tray Lamp
LDAP Underhood Lamp
LEBP Ext. Mirrors w/Supplemental Signals
LECP Exterior Mirrors Courtesy Lamps
LEPP Body Color Exterior Mirrors
LETS Traveler/Mini Trip Computer
LHEP Rear Dome w/On/Off Switch Lamp
LMEP Halogen Quad Headlamps
LMGS Automatic Headlamps
LNJP Fog Lamps
LPES Cargo and CHMSL Lamp
LSAP Security Alarm
MBPP Body Color Front Fascia
MBQP Body Color Rear Bumper w/Step Pads
MDAS Front License Plate Bracket
MENS Front Wheel Spats
MFNP Body Color Grille
MGAS Ram's Head Badge
MHLS Rear Wheel Well Liners
MNKP Body Color Door Handles
MPPS Rear Wheel Spats
MP8P Delete Black-Out Tape
MS2S Ram 1500 Badge
MUSS 4X4 Badge
MW5P Hemi Badge
MXCS Front Bumper Sight Shields
NAA Federal Emissions
NEXP Dual Rear Exhaust
NFWS 26 Gallon Fuel Tank
NHDP Heavy Duty Transmission Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCP Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PXR Brilliant Black Crystal Pearl Coat
QXRS Brilliant Black Crystal Pearl Coat
RAAC All Radio Equipped Vehicles
RCGS 6 Speakers
RDDP Fixed Long Mast Antenna
RDZP Steering Wheel Mounted Audio Ctrls
RESS Uconnect 130 AM/FM/CD/MP3
RSCS SIRIUS Satellite Radio
RSUP Audio Jack Input for Mobile Devices
SBAS Power Rack and Pinion Steering
SCVP Leather Wrapped Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
SHFS Rear Stabilizer Bar
SUAS Tilt Steering Column
TBMS Tire Carrier Winch
TBSP Full Size Temporary Use Spare Tire
TUKP P275/60R20 OWL All Season Tires
TZAP Goodyear Brand Tires
WF1S 17" Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
WP2P 20X9.0 Aluminum Chrome Clad Wheels
XA8S Non Adjustable Pedals
XBMP Remote Start System
XBNP Tip Start
XBSS Pickup Box
XFKS 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XGDP Universal Garage Door Opener
XGMP Tire Pressure Monitoring Display
XJCP Locking Lug Nuts
XJJS Locking Tailgate
XJ8S Body Color Fuel Filler Door
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X88S Tire & Wheel Parts Module
X9AP For More Info, Call 888-539-7474 ?
X9BP 1-Year SiriusXM Radio Service
YAAS Build To U.S. Mkt. Specifications
What the heck is X9AP?
NS
