Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 08-30-2013, 06:37 PM
Karaitt Karaitt is offline
Vehicle: 2004 Dodge Ram
Trim Level: SL
Color: Pewter
Karaitt is on a distinguished road
Question haul/tow button
I have a 2004 Dodge Ram 1500 Powertech v8 4.7L. We have been moving a lot of tree limbs lately, and not sure if I need to turn on the Haul Button when we have so many lbs in the bed. And how fast can we drive with all that weight in the bed? Thanks.
Old 08-30-2013, 06:41 PM
Hermes1's Avatar
Hermes1 Hermes1 is offline
Vehicle: 2012 Ram 1500 Sport
Color: Flame red
Rep:2554
It won't hurt to use it. You can tell if you need to use it if the tranny is hunting a lot, then you might want to use it.
Best, Bruce
Sure you can take my truck, the keys are under my Akita.
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
It does help to turn the tow/haul on when you have a bed full of stuff, its actually made for just that purpose. As long as you have your tree limbs secure you can operate safely at highway speeds.
Old 08-30-2013, 06:43 PM
Rep:2625
the key is, if your Ram is shifting up & down frequently, use the tow/haul mode
don't forget, your transmission may be an automatic, but you can help the engine by dropping a gear or two
whether you are using the normal mode or tow/haul
tow/haul holds the gear for longer periods of time & allows the engine torque to work better
Old 08-30-2013, 06:48 PM
Trim Level: SL
Color: Pewter
Thank You all, we were really wondering about that because it started to overheat a bit because with the extra weight it(BANDIT) really seems to idle high.
Old 09-01-2013, 11:07 AM
Hermes1's Avatar
Color: Flame red
Rep:2554
The overheating could be a function of the heavy weight you are hauling and the tranny working hard ie. what GT Yankee is referring to when he suggests dropping down a gear or two. It could also be a problem with the cooling system, or both. IMHO I would have your cooling system evaluated first and if operating correctly or after having it serviced, then use tow/haul mode and dropping a gear or two.
Best, Bruce
