Old 08-30-2013, 05:40 PM
Trober's Avatar
Trober Trober is offline
Vehicle: 2006 Dodge Ram 1500 4.7L 2WD
Trober is on a distinguished road
Default Will this T fitting work on a trans cooler line?
I have a 2006 dodge ram 1500 4.7l automatic and I'm looking to put in a trans temp gauge and on the sending unit I figured I'd use a npt to barbed T fitting but I need to know how size the barbed end needs to be? 3/8"? I don't wana cause any fluid blockage. Here is a T the style that I'm going to get.http://www.pneumadyne.com/thread-barb-fittings-p-2088-l-en.html?language=en
Old 08-30-2013, 07:22 PM
DRX350's Avatar
DRX350 DRX350 is offline
Vehicle: 1996 Dodge Ram
Trim Level: SLT Lariat
Color: Blue-ish
Rep:118
DRX350 will become famous soon enoughDRX350 will become famous soon enough
3/8" ID should be good, most aftermarket trans coolers use 1/4 fittings anyway...
Old 08-30-2013, 08:49 PM
Trober's Avatar
How much pressure is on these lines
Old 08-30-2013, 09:58 PM
DRX350's Avatar
Color: Blue-ish
Rep:118
under freak circumstances, ~100psi, normal operation 45-75psi
Old 08-30-2013, 10:05 PM
Trober's Avatar
I think ill just put it in test port 3 at least then I won't have to worry about a line leakin or falling off and burning up my trans
Old 09-03-2013, 07:57 AM
TransEngineer TransEngineer is offline
Vehicle: N/A
Rep:358
TransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really niceTransEngineer is just really nice
Be advised that the "test ports" on the passenger side of the bellhousing are dead-headed (they are passages that just dead end at the pipe plug), so you can check PRESSURE there, but they have no flow, so they will NOT give you an accurate "to cooler" temperature reading.
