Needing info for engine build coming up soon! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 08-31-2013, 12:02 AM
BoostedSport BoostedSport is offline
Vehicle: 2003 Ram Sport
BoostedSport is on a distinguished road
Default Needing info for engine build coming up soon!
I have a few questions on my upcoming motor build as I see my 120k mile factory bottom end won't be liking the whole forced induction thing. My truck is an 03. As of right now I have inertia's 214/218 cam and ported, polished, milled performance heads. I've got a PT7675 ill be pitting on soon. My future build will be a 5.7 base 370ci, I've spoken with Scat several times and have most of the kinks worked out on the rotating assembly.
So here's the questions; mind you I will be building this myself
•I'm wanting to run the performance Eagle heads, for their flowing capabilities. What all would I need to put these heads on an 03-05 block?
•Also, what intake manifold would I have to run? And are there any aftermarket manifolds out there?
•head studs or bolts? Does any body have any input on rod bolts or crank cap studs?
•does anyone have any other ideas or upgrades they'd like to suggest?
•what can a factory bottom hold as far a power?
PS; I've ran E-85 on some other turbo builds I've done, but from what I hear we cannot really advance the timing too much what's up with that?
Thanks Pat
Old 08-31-2013, 01:32 AM
I did just find this though
http://www.carcraft.com/techarticles...cylinder_head/
Old 08-31-2013, 09:14 AM
Fasthemiram11's Avatar
Fasthemiram11 Fasthemiram11 is offline
Vehicle: 2016 Ram Quad Cab
Rep:15
Fasthemiram11 is on a distinguished road
I'd just forge the bottom end with a 6.1 crank k1 rods and wiseco pistons. Slap on some eagle heads and a 6.1 intake
2011 RCSB 12.41
2012 RCSB 13.99
2016 QCSB 13.8
1992 Turbo Hemi D150 really fast times coming
Old 08-31-2013, 10:08 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
pretty much this with head studs at a minimum. I'd go with ARP everything if you can and/or depending on how much boost you have planned.
Old 09-02-2013, 06:28 PM
K1 rods for for a 6.1? And what can the 6.1 crank hold hp wise?
I plan on running 18-25ish… soo arp will be a must haha
Old 09-03-2013, 05:29 PM
Stampede4.7 Stampede4.7 is offline
Stampede4.7 is on a distinguished road
What year PCM do you have?
Stampede.
Old 09-03-2013, 08:46 PM
Stampede.
I have an 03, but ill be using i-EMS3 and Superchips just like frosting is using.
