Need Help with my 99 before I set it on fire - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-31-2013, 02:37 AM
Anken31 Anken31 is offline
Vehicle: 1999 Dodge Ram
Trim Level: Laramie SLT Quad Cab
Anken31 is on a distinguished road
Exclamation Need Help with my 99 before I set it on fire
Sorry for the super lengthy post, but I want to be as detailed as possible...
I have a 1999 Dodge Ram Laramie 4x4 Quad Cab 5.9L, has 230k+ miles. Early June I found my A/C Compressor wasn't plugged in. So I plugged it in, charged the system and had Ice Cold Air. Two days later, my battery was dead. Had it tested, and it needed replaced. Got a new battery, installed it and was good to go. Not sure if this was where the problem started, but I noted it just in case it may have been.
A Couple weeks later, as I was leaving work, my truck wouldn't start. It cranked and cranked but no start. I checked for spark, and there was none. So the next day I went and swapped the ignition coil(it was only 2 months old). Truck still wouldn't start. After work, I decided to make sure it wasn't going to start before I got a ride home. It started, drove home and back to work the next day. Went to leave for lunch, it started, moved 5 feet, died, and rolled into a new parking spot. Didn't mess with it for 2 days. Left work, started right up. Made it 5 blocks and it died. Got pushed all the way home by a Ford(because Ford's always start!).
I figured I'd start diagnosing/changing some parts. I changed Spark plugs(twice, in case my motor didn't like the first as there was no change) , wires, stator, Cap & Rotor. Truck started, but sounded like there was nothing coming out of the exhaust(Had no muffler, and was super quiet). And then it died, and wouldn't start again. So I took it to a shop. They changed Crank sensor(twice, in case the first was faulty), and still had the same issue, wouldn't start. They then disconnected the exhaust from the manifold and it fired right up. So they changed the catalytic converter. Started right up, and would move down the street. I went to work.
Now onto the issue I am having now:
Left work, went to get out in traffic and it fell on its face. Ease into the throttle and it would accelerate fine, but try and get on it hard and it hesitates/misses/backfires and falls on its face, sometimes stalling out. Couldn't figure this out to save my life. I changed the o2 sensors, as this seemed like a pretty good place to start with the symptoms I was having. Had no affect on performance. So I took it do Dodge stealership. They had it 10 days, changed PCM, did a fuel flush, told me it was running 1000 times better. So I sent my brother to pick it up(4:45pm and they close at 5pm and I was at work). I got home from work, wanted to go fishing. Got in the truck, started it up, moved 5 feet and it died. Wouldn't start again all weekend. Went back to Dodge on Monday. They had it towed back and would look at it the next day.
Dodge also informed me that they checked fuel pressure, at 50PSI, and said the volume was great. Had the cylinder pressure checked, and all were between 138-145psi.
Tuesday afternoon they call and let me know they couldn't figure it out. They looked at everything(so they said). And it sounded like there was no exhaust coming out. So they disconnected the exhaust from the manifolds and it started right up. Said I could pick it up anytime(no charge this time).
So now here I sit, $1500 into the truck, not including parts I threw at it, and still no change in performance whatsoever. I just ordered a new Denso fuel pump Wednesday, and it came in this afternoon. I will be changing that out tomorrow, but I have a feeling I am still just "throwing money away" as I don't feel this is the issue.
Any suggestions!? I'm pissed off and tired of this truck, and ready to set it on fire(if I didn't have a 16 month old girl, and a 5day old baby boy it woulda been done already).
Old 08-31-2013, 10:44 AM
spoiler's Avatar
spoiler spoiler is offline
Rep:372
I feel your pain but don't set it on fire! In the year 2029 your son will be 16 and he's gonna be stoked that his ol' man saved hime a 99' Ram. ( can you say badass son?) I'd say give it to your daughter in 2024 but she's gonna want a new car. Sorry I can't help more than this. LOL
Old 08-31-2013, 10:46 AM
Yeah, He'll be stoked because I'd send them off to school, and let him know, "If it breaks down, it's on you. So it's a good time to look for a job."
Old 08-31-2013, 08:24 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
I feel your pain. Hope you get this issue resolved.
Old 08-31-2013, 09:37 PM
Rep:2929
First thing you posted was that the A/C Compressor was not plugged in
How did it run BEFORE you plugged it in ??
Old 09-01-2013, 12:11 PM
Trim Level: SLT & Sport
Color: 1 Blk,1 Red
Rep:36
Change your intermittent fuel pump, or rig up a thumper for your fuel tank. No, really! Better yet, buy, borrow or rent a fuel pressure gauge and stick it to the wiper when it runs and make sure to thump the tank before you try and start it! then drive around til it turns into a bad actor. no variations in pressure, about 35 PSI allowed. $200 + - for a pump. I played this game to the tune of about $1200 in parts about 10 years ago. It was the pump all the time. I'd bet money on it being the problem. Good luck!
Old 09-01-2013, 10:22 PM
It ran fine. then the battery died. A/C Compressor is Not hooked up now, and has not been hooked up since we put the new battery in.
Already did all the fuel pressure testing. Tests showed fine. But I had already had a fuel pump on the way and it's already installed in the truck. This is not the problem, as it still acts the same exact way. I am 190% sure it is NOT Fuel related.
Old 09-02-2013, 01:46 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
Haven't seen anywhere on the diagnosis that you checked for spark. When it dies, do you check it for spark? You've changed everything but the coil. If you don't have any spark, change the coil and see what happens.
Old 09-02-2013, 01:53 AM
In the 2nd or 3rd paragraph it does state we checked for spark and had none. And that we replaced the coil, and it was only a couple months old when we started having problems.
Old 09-02-2013, 02:25 AM
Rep:2968
Missed it I reckon. Well, crap. Ok, but you don't have spark. This stator you said you changed, are you referring to the module in the distributor?
