Old 08-31-2013, 01:42 PM
06 BigHorn's Avatar
06 BigHorn 06 BigHorn is offline
Vehicle: 2012 Dodge Ram
Trim Level: Express Quad Cab
Color: Deep Cherry Red
Rep:153
06 BigHorn has a spectacular aura about06 BigHorn has a spectacular aura about
Question 180 degree thermostat
Installed a Duralast 4128 180 degree thermostat. Whats the normal coolant temperature range after installing one compared to the stock thermostat? I'm stall getting temps in the 240's
It's a truck, not a cream puff
Old 08-31-2013, 02:10 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Should be around 185º
I used a Jet 10183 (since 2010), never see temps over 190º
I believe stock is around 210-220, cant recall
Old 08-31-2013, 02:16 PM
jerseymike's Avatar
jerseymike jerseymike is offline
Vehicle: 2013
Rep:116
jerseymike will become famous soon enoughjerseymike will become famous soon enough
You most likely have air in the system. Try squeezing the air out of the upper radiator hose. I had the same problem. Mine runs 185 to 190 then back to 185 all the time.
Old 08-31-2013, 04:32 PM
06 BigHorn's Avatar
Rep:153
Had some air in it . Can't get it any higher than 194 now before it starts going back down.
Thanks
Old 08-31-2013, 04:41 PM
jerseymike's Avatar
Vehicle: 2013
Rep:116
Your welcome. Yea I like it running at 185. Makes me feel safe with it that cool and helps the motor to run a little rich to compensate for CAI, headers, etc. Also the oil will be cooler, usually around 195 to 200.
Old 09-01-2013, 01:44 PM
gsxrfarm's Avatar
gsxrfarm gsxrfarm is offline
Vehicle: 2012 ram express
Trim Level: express
Rep:47
gsxrfarm is on a distinguished road
how is your mpg after changing it ive seen a lot of debates over this I know on my old ls1 when I put a 180 in it it helped mine a little
2012 express , s&b cai, magnaflow, bullydog, catchcan 24" rims
Old 09-01-2013, 01:46 PM
06 BigHorn's Avatar
Rep:153
Haven't driven it enough yet. But before with the HemiFever 93 tune I was in the low 16's.
Old 09-01-2013, 03:16 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
what did you set you efan on/off settings at?
Old 09-01-2013, 03:26 PM
06 BigHorn's Avatar
Rep:153
Honestly I don't know, left that to Hemifevers tune. But the fan seems to come on rather fast
Old 09-01-2013, 08:05 PM
CHVYKLR's Avatar
Rep:252
As long as it doesn't come on before 180. That way the tstat fully opens. 194 isn't bad by any means but it should still stay in the 180s depending on your fan settings.
