motor wont wont start need help!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-31-2013, 05:19 PM
overtheedge86 overtheedge86 is offline
Vehicle: 98 Dodge Ram
Color: blue
Rep:24
overtheedge86 is on a distinguished road
Default motor wont wont start need help!!!
I picked up a Ram that had been sitting for a few years. drained tank, all fluids, replaced cap and wires. It was running ok a little rough but running. Today i drove it into the barn to replace spark plugs and the oil sender as well as add a manual oil gauge (oil PSI was fluctuating and dropping to zero).
So today I started the truck and moved it. Changed the plugs and started again to make sure i didnt cross any wires. Next i tackled the new oil sender, I tee'd into the stock sensor location and added the pickup for a manual gauge as a back up. Went to start again and it cranks but wont start!?
Pulled a plug and seen spark, plugs smelled like gas so its getting fuel. I tried starter fluid and got a puff/fireball out of the intake but no start. I'm at a loss of what to check next.
Old 08-31-2013, 06:09 PM
Ford Killa Ford Killa is offline
Vehicle: 2011 Dodge Ram 1500 LONE STAR
Color: Silver Metallic
Ford Killa is on a distinguished road
could of jumped time had a ford do that once after i changed the oil and plugs.it still got spark .
Old 09-01-2013, 08:03 AM
Color: blue
Rep:24
Well this morning i unplugged and checked the cam and crank sensors, then the coil. Plugged them back in and she fired right up? I'm thinking either the cam or crank sensor is on its way out.
