RPM fluctuation / idle issue - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-31-2013, 10:15 PM
btah btah is offline
Vehicle: 2003 Dodge Ram 1500 SLT
btah is on a distinguished road
Default RPM fluctuation / idle issue
Hello, new to the forum. I hope through this post we can narrow down my problem and also help some other along the way that might be searching for a resolution.
The problem:
My truck will sometimes die at idle, lets say once out 30 trips around town. It will also feel like it is going to die and I have to pump the gas for a few seconds to get it back to normal, usually when just pulling away, say once every 15 trips around town. If I am in park and try to keep the idle at 1000RPM I will get hesitation and surging between 900 to 1100 RPM. Also, if I try to keep it at 1000RPM and turn the wheel to add some load, the idle will drop to @600RPM and surge to@1200 RPM when I let go of the wheel. IF I am in drive, other than the occasional die I can't reproduce the hesitation and surging if I keep it at 1000RPM. No codes (using the key on-off 3 times and also the trip button while turning the key on methods).
Here is what I have done to try to solve the problem (truck has 66,000 miles):
plugs
oxygen sensors
TPS
PCV
removed and cleans TB and IAC, neither of which struck me as being very dirty.
Most of the posts I read say "replace the TPS" or "replace the IAC" without a whole lot of explanation behind the suggestion. To help with the investigation I did the following tests:
TPS unhooked
IAC unhooked
TPS and IAC unhooked
TPS and IAC both hooked up
Results:
TPS unhooked and IAC hooked up
Idles a little rough at 600 RPM
If I keep it at 1000RPM it stays pretty steady. If I turn the wheel it will drop to about 900 RPM and surge to @1100 RPM when I let go of the wheel.
TPS unhooked and IAC unhooked
Idles rough at about 400RPM
harder to start
If I keep it at 1000RPM is stays pretty steady . If I turn the wheel it will drop to about 900 RPM and surge to @1100 RPM when I let go of the wheel.
I just realized the results of the above two are pretty much the same except for the initial idle.
TPS hooked up and IAC unhooked
much harder to start, need to give some gas to keep it going initially.
If I keep the idle at 1000RPM it hesitates and surges between 900RPM and 1100RPM. If I turn the wheel it will drop to @600RPM and when I let the wheel go it surges back to @1200RPM and then back to 1000RPM.
Both hooked up
Starts fine and idles smooth at 600RPM.
If I try to keep it at 1000RM it fluctuates between @900 to @1050 RPM. If I keep it at 1000RPM and turn the wheel it drops to @600RPM and then surges back to @1200 RPM before returning to 1000RPM.
So, I am not sure what to make of all that. Anyone have any thoughts? And, thanks in advance
Old 09-01-2013, 03:54 AM
RogerRamJet's Avatar
Vehicle: 2014 RAM 1500
Trim Level: Sport 4X4 CC
Rep:2968
I have the same engine and can address the surging when you turn the wheel. That is the power steering pump wanting more power so the computer gives it a little more. As far as the truck wanting to die at idle, mine has done that on occasion, and I chalk it up to that's just what it does. Doesn't happen as often as yours, but it has happened.
I gotta ask, why are you trying to keep your idle at 1000rpm? Mine idles great between 5 & 6.
Old 09-01-2013, 11:02 AM
I don't think I was real clear on keeping the idle at 1000. My normal idle is around 600. I don't experience any fluctuations if I just leave my foot off the gas. However, if I raise the idle slightly by keeping my foot steady on the gas, I experience the fluctuations. It seems that if I try and keep it around 1000 I see the most fluctuation. The higher I raise it about 1000 I see less an less fluctuation. If I get up to about 2000 the fluctuations almost go away. So, foot off the gas, pretty good idle. Try to keep it around 1000 the RPM fluctuate.
Old 09-01-2013, 11:04 AM
Also, it may just be a progression of the issue but we have had a few really warm days over the last week and it seems like the issue is slightly worse.
Old 09-01-2013, 06:22 PM
Rep:2968
With the heat making it worse, that points to the AIT (Air intake temp.) sensor.
Old 09-01-2013, 08:15 PM
Thank you for the response. I'll search around but do you know if there is a way to test it? Being a temp sensor I doubt it but the question is worth a shot. Maybe functionally testing it like unhooking it?
Old 09-01-2013, 08:21 PM
And just to be sure, the AIT is the one plugged into the big black box (that's a technical term) on the top of the motor, right?
Old 09-01-2013, 11:49 PM
Rep:2968
Don't wanna get too technical now, so we'll go with the big black box, yes. Pull it out and clean it up a bit. See if that helps any.
Old 09-02-2013, 01:14 PM
It is spotless.
Old 09-06-2013, 07:04 PM
any other thoughts?
iac, idle, idle air control valve, throttle position sensor, tps
