Old 09-07-2013, 12:01 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Not off hand, I don't. Bumping it to the top so someone else may see it.
Old 09-07-2013, 07:56 PM
btah btah is offline
Vehicle: 2003 Dodge Ram 1500 SLT
btah is on a distinguished road
Just to add... Running around town today it died once and felt like it was going to die 2 other times. All three happened when backing out and going from reverse to drive. As soon as I started to pull away in drive the hesitation/dieing happened.
Old 09-12-2013, 08:19 PM
I also have the airbag light on. It is on most of the time but every now and then will go away for a few minutes. I didn't think this was relevant but I happen to come across some other information that indicated some components in the airbag system (the clock spring) might cause issues with a TPS.
Old 09-14-2013, 05:24 PM
Anyone have any ideas?
Old 09-15-2013, 06:05 PM
I tried a new IAC from autozone but I had a hard time keeping an idle. It would idle at @500 RPM and die every now an then. I put back in the original IAC and also put back in the original TPS since the new ones seemed to make the issue worse.
Old 09-29-2013, 05:01 PM
Well, here's the story. One of the things I did a few months ago was to replace the O2 sensors. I used Bosch Premium. I couldn't remember if the stalling and wanting to stall happened before I replaced them or not. I put back in the original O2 sensors and the problem I had of wanting to die seems to have gone away. I post again if the problem comes back.
Also, and I have no idea why (any opinions would be appreciated), as soon as I put back the factory O2 sensors, by airbag light went out (has been on for a month or so solid). I think the airbag light originally came on some time after I replaced the sensors.
Thanks to those that took the time to respond to my posts. Hopefully this can help someone out.
Old 09-30-2013, 12:29 AM
Rep:2929
That's really weird about the airbag light. That's a real head scratcher...
Old 10-01-2013, 04:44 PM
Airbag light has came on and went off a few times since. It appears to be an odd coincidence.
iac, idle, idle air control valve, throttle position sensor, tps
