1995 2500 47RH no OD - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 10-03-2013, 01:53 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Originally Posted by cumminskid View Post
I'll have to do some digging and find my sensor from my 94. I put the temp sensor for my trans temp gauge in its place and wired in a resistor so it would shift into OD. Thanks again for all the help. I'm hoping to get this going before snow starts to hit. My 94 is a two wheel drive and I need 4 wheel drive in my neck of the woods
Always happy to help. Very smart of use that gauge temp sensor in place.
I haven't lived up north in such a while, down here in FL I only need LSD rear end because of some of the soft soil (sand). Anyways, stay in touch.
Old 10-03-2013, 02:39 PM
richmond richmond is offline
Vehicle: 1999 Dodge Ram
Rep:177
richmond has a spectacular aura aboutrichmond has a spectacular aura about
Interesting post. My friend and fellow hauling partner has a 95 12v 2wd. I'll print this post. R...
Old 08-10-2014, 10:26 AM
cumminskid cumminskid is offline
Vehicle: 1994 Dodge Ram 2500
Color: Lime Green
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
cumminskid is on a distinguished road
Well I finally got some motivation to work on this issue more. I wired in a switch to ground the OD solenoid manually and it will shift into OD when using it. So at least I know everything internal in the trans is ok. I tried switching the trans temp sensor with a resistor since I can't locate my other sensor and it still won't shift into OD on its own. Time to do more digging to find the cause!
Old 08-10-2014, 10:59 AM
ramvan2500's Avatar
Rep:141
This is such an old thread. I'm going to have to refresh my memory on the issue. Knowing it isn't a mechanical fault is good, now you just have to trace down the bad wire or sensor.
Old 08-10-2014, 12:56 PM
Color: Lime Green
Now that I know everything mechanical is ok I'm going to start checking continuity between sensors and PCM. Do you know of anything that controls the shift to OD besides the tps, trans temp, and vss?
