Old 09-01-2013, 11:01 PM
CherryRam's Avatar
CherryRam CherryRam is offline
Vehicle: 2012 Ram 1500
Color: PRP Deep Cherry Red
Rep:77
CherryRam will become famous soon enough
Default Cleaned Up Spyder Headlight Wiring
When I first put my spyder projectors in I didn't plan it out much just winged it. It worked but it was a mess of wires and if I needed to take the headlight out it was a pain to make sure things went where they needed to. I also needed to wire in a resistor for my led signals so I figured I'd wire them with a harness connector.
So what I ended up using for a harness since I was too cheap to buy one was a 4 wire connector for a heated O2 sensor off a grand prix (luckily pick n pull is full of them)
Soldered the connector to the headlight
Cleaned it up with some split loom.
Did the same to the harness on the truck. You can see the led resistor mounted to the rail at the back.
Plugged it in and checked and everything worked. Now there's a connector for the headlight bulbs, the signal and the halos and leds. No more fidgeting with 5 little wire connectors that look like a rats nest of wires.
-Heather
12' Ram 1500 Sport
03' Acura RSX-S
07' Suzuki GSXR 750
Old 09-01-2013, 11:30 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Nicely done! Nothing worse than a rats nest of wires. I always split loom and make it purdy!
Big Red my old 2011 Sport
Old 09-02-2013, 12:57 AM
RogerRamJet's Avatar
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
Very, very nice job. Taking pride in your work. Reps for the outstanding work and having pride in it.
Old 09-02-2013, 01:05 AM
CherryRam's Avatar
Rep:77
Thanks guys Gotta do the other side tomorrow, had to load up a dirtbike midway through working on it.
-Heather
12' Ram 1500 Sport
03' Acura RSX-S
07' Suzuki GSXR 750
