United Radio
Old 09-02-2013, 11:20 AM
ff6cav's Avatar
ff6cav ff6cav is offline
Vehicle: 2008 Dodge Ram
Color: Inferno Red
Rep:104
ff6cav will become famous soon enoughff6cav will become famous soon enough
Default Battery Terminal Corrosion
A few months back I noticed that my negative battery terminal had some corrosion on it- I cleaned it with some terminal cleaner and then sprayed the terminals with a battery treatment to prevent corrosion. However, I've noticed recently that the corrosion is coming back (a few weeks later). It's not as bad as it had been, but it's there- anybody else have this problem? I'm wondering if it's a battery issue, or more so the terminals on the cables?
"Little Red Wagon"
2008 Ram 1500 Big Horn
Old 09-02-2013, 12:03 PM
RogerRamJet's Avatar
God Bless Texas!
Vehicle: 2005 Ram 1500
Trim Level: Lonestar QC
Rep:2929
A leaking terminal is what is causing the corrosion. You can either keep cleaning it or get a new battery.
Old 09-02-2013, 12:24 PM
Grubrunner's Avatar
Rep:3883
Was the corrosion on the actual post of the battery's terminal or was it more concentrated around the connector that slides over the post?
Grub out!
Old 09-02-2013, 01:35 PM
ff6cav's Avatar
Color: Inferno Red
Rep:104
More so on the connector, and it looked like just some residual on the actual battery post
"Little Red Wagon"
Old 09-02-2013, 08:18 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
i always hit my terminals with Castle Muscle Grease...it works great, but ive never really considered that an excess of corrosion cold be a bad battery...thanks RogerRamJet.
Old 09-02-2013, 08:48 PM
God Bless Texas!
Rep:2929
It's not necessarily a "bad" battery, but it is a leaking battery.
Old 09-02-2013, 09:01 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
i always clean up the posts and connectors than spray them with white lithium grease and usually they are good for a few months. the only batteries i have ever not had corrosion on were the gm side post type. even on my kenworth all the battery terminals always get corrosion. and that truck has 4 batteries.
Old 09-02-2013, 09:13 PM
I push the skinny pedal
Rep:3277
It may sound weird, but the few times I've had battery corrosion, putting some vaseline on the post creates a barrier between the two different metals.
Kurtis
Old 09-02-2013, 10:07 PM
ff6cav's Avatar
Color: Inferno Red
Rep:104
Thanks for the info so far. I guess my next question is, can the wire connector be replaced if the corrosion gets too bad? I've dabbled with some electrical accessories, but have never dealt with the bigger gauge electrical work on vehicles.
"Little Red Wagon"
Old 09-02-2013, 10:26 PM
Hermes1's Avatar
Hermes1 Hermes1 is offline
Vehicle: 2012 Ram 1500 4WD Quad Cab
Rep:2538
Yes it can, but you may want to check to see if any part of the wire is also affected, in which case you will want to replace the wire and connector.
Regards, Bruce
Sure you can take my truck, the door is un-locked and the keys are under my Akita.
