Looking for helpful ideas to raise tonneau straight up - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Old 09-02-2013, 11:29 AM
Black-Blade Black-Blade is offline
Vehicle: 2003 Dodge Ram 1500 4x4 QC
Black-Blade is on a distinguished road
Default Looking for helpful ideas to raise tonneau straight up
Just wondering if anyone else has built a system for being able to raise your tonneau cover straight up for 3 feet or more. I had built some panels for all four sides of my box and a makeshift top for it that I draped a tarp over, for some camping, but first thing I had to do was remove my tonneau and leave it at home. I was thinking to make some kind of scissor like lifts on each side (then figure out how to make both sides rise equally) I could then put my panels in place and just lower the tonneau back down a bit to rest on the panels. It would be a perfect roof for my little makeshift camper.
In google searches I have found a bit of info on a system thats no longer available..TopUp Campers I think it was, that was almost exactly what I was thinking of. I found a link to an installation of that system:http://www.sporttruck.com/techarticl...r/install.html but wondered where to get those hydraulic cylinders and pump etc that came in the kit or would maybe use on of those little 12 volt tire pumps to push up air cylinders??
Making some scissor lifts out of a few pcs of metal is no big deal, I am stumped at the method of raising the scissors, I've thought of a threaded rod along the bottom slide rail that will push the rails up, but other than alternating sides and going up little by little, it might bind.
Old 09-05-2013, 12:10 PM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
hmm that is a good idea. I have no clue how to go about it efficiently.
Good luck!
Old 09-05-2013, 01:46 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
http://www.silvershieldsystem.com/
This is a solid cover that is targeted at land surveyors, which I happen to be one. Our office never had one but we have another office that did. Its kind of nice since you can lift one side or both sides and have it come straight up about 2 or 3 feet like you want. You probably don't want one of these and as I recall, they are very pricey, but this might give you some ideas on how to make one. Its nice since you don't have to lift all four corners at the same time but can lift one side then the other or just lift the back like a regular hard cover.
Old 09-05-2013, 04:12 PM
toober's Avatar
toober toober is offline
Trim Level: Tradesman
Rep:26
toober is on a distinguished road
Sounds like a good project for a 5th wheel company that has popup campers. Instead of the whole trailer, just make the popup.
Old 09-05-2013, 08:18 PM
ramit355's Avatar
ramit355 ramit355 is offline
Vehicle: 2014 1500 4x4 CC Laramie 392
Trim Level: Laramie Crew Cab
Rep:28
ramit355 is on a distinguished road
i have a roll n lock e series hit button and top rolls up against cab. Haul what you want close it when done with a button and lt locks. Love my Roll n Lock!!!
Old 09-05-2013, 08:51 PM
TheShortyRam TheShortyRam is offline
Vehicle: 2012 dodge ram
Trim Level: express
Color: mineral gray
Rep:23
TheShortyRam is on a distinguished road
Linear actuators?? Ive seen many trucks in the show scene with them
