Old 09-02-2013, 01:02 PM
bowieknife's Avatar
bowieknife bowieknife is offline
Vehicle: 2013 Sport CC, 5.7L, 8spd
Trim Level: Sport Crew Cab
Rep:71
bowieknife will become famous soon enough
Send a message via Yahoo to bowieknife
I've had the 5 speed Hemi (not much different than the 6) with 3.55's and thought performance was disappointing. Now with the 8spd and 3.92's it's a different world. I also like that the 8 speed isn't a native Chrysler product and a proven entity in many other vehicles....(although I'm not sure where the 6 speed came from to be honest.)
Old 09-02-2013, 01:09 PM
edge35's Avatar
edge35 edge35 is offline
Trim Level: Laramie Longhorn 4x4
Rep:70
edge35 will become famous soon enough
Maybe they have tons of the old transmission and are figuring out how to get rid of them.
Was actually a pretty good strategy at first. When they unveiled the 2013s they talked and talked about the 8 speed and active grill shutters and made it seem like it would be the only transmission that the truck that came with. A lot of people flocked to the dealers thinking that they were going to get it but then found out that it wouldn't even be available until oinths later. But, as any good car salesman will tell you, once the potential customer is actually in the dealership then most of the work is done.
Off the top of my head I can't remember reading any of the early 2013 info that said the 8 speed would be optional. It seems like it all said something to the effect of "New for 2013" but omitted "optional" or "late/limited availability". In my case it wouldn't have made a difference because when I needed a new truck I needed a new truck and didn't have time to wait for the new transmission to come out. My choice was between the rather aging Ford and Chevy models or the Ram. As much I as I prefer the performance of the Ecoboost it all came down to the interior where the Ram beats the pants off the others.
2013 Laramie Longhorn 4x4
6 speed (although the 65RFE is really a 5 speed), 3.55, air suspension, anti-spin, 20" Goodyear Wrangler SRA tires (aka crap), sunroof, Bakflip Fibermax & BakBox, bed extender, 8.4AN, black/cattle tan interior
Old 09-02-2013, 01:21 PM
edge35's Avatar
Rep:70
It is a Chrysler product.
In the late 90s they came out with the 45RFE 4 speed. It technically had 5 speeds but since most of the time it didn't use them they labeled it as a 4 speed. They then added another gear, made a few minor tweaks, and then it was the 545RFE. Once again they did the right thing and called it a 5 speed even though it technically now had 6 forward gears.
Take that 5 speed, make a software change, and relabel it a 6 speed. Now you have something new to advertise for the 2012 model year to help clear out inventory before the 2013s arrive.
Old 09-02-2013, 01:30 PM
dawoodsman dawoodsman is offline
Vehicle: 2013 Ram 1500 Crew
Trim Level: Outdoorsman
Color: True Blue Peal/Mineral Gray
Rep:92
dawoodsman will become famous soon enough
Did you have the dealer conduct a regional dealer search for exactly what you want? Could be your favorite is out there somewhere, just sitting on another dealers lot. Mine came from a state away with a few hundred miles on the odometer by the time I drove it home. If your dealer won't do that, try another one. I might guess the stock of 13's is getting lower now but you never know unless someone makes the effort to look.
Old 09-02-2013, 01:39 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
Originally Posted by edge35 View Post
Guess it comes down to how much the savings mean to you. I regret not having the 8 speed. I don't even think the 65RFE should be advertised as a 6 speed since it only uses 5 gears when you just put it in D (like probably 99% of owners do). And no active grill shutters without the 8 speed if that's important to you.
Having said that, though, let me also add that I've had no problems with my transmission and perhaps there is something to be said for lower tech and less equipment to break (not an issue when you are under warranty, though)
Edge35; You and I must be the one percent that uses our ERS every single start up. And that's a no shizzer bud.
Old 09-02-2013, 01:52 PM
The Crow 1994's Avatar
The Crow 1994 The Crow 1994 is offline
Vehicle: 2013 1500 Big Horn Crew 4x4
Trim Level: Hemi 5.7L w/8 Speed
Color: Copperhead Pearlcoat
Rep:56
The Crow 1994 will become famous soon enough
I was in the "not going to settle" crowd when it came to purchasing my truck. I'm hoping my truck will give me a good 10-15 years, so I wanted to make sure I had no regrets prior to making the final decision. I guess it all depends on how high up the 8 speed transmission is on your priority list. From reading your post, it seems pretty important to you. It was for me, as well. After test driving both, it was 8 speed or nothing for me. Unfortunately, the 8 speeds were just being built and I couldn't find the truck I wanted within 2000 miles. So, I had to order mine (and probably get less off at the dealership).
Mod List: Line-X Platinum Spray-On Bedliner, BakFlip VP Tonneau Cover, TufTruck 1223-V HD Coil Springs, Bilstein 4600 Shocks, Air Lift 1000 Air Bags, Air Lift Wireless One Remote System with On-board Compressor, & Weathertech Digital Fit Floor Liners
Old 09-02-2013, 03:40 PM
astonius astonius is offline
Vehicle: 2014 Ram 1500
Trim Level: Laramie Limited 6'4"
Rep:30
astonius is on a distinguished road
The 8 speed being a ZF transmission is what sold me on it. I've had ZF transmissions before, and they are rock solid. Coupled with its performance and fuel economy there's just no way I would have settled for a 6 speed Chrysler transmission unless I had no choice.
Old 09-02-2013, 03:50 PM
dodgehemi0 dodgehemi0 is offline
Vehicle: 2013 Sport Crew
Rep:26
dodgehemi0 is on a distinguished road
dont get it without the 8speed it is worth the wait.
Old 09-02-2013, 04:59 PM
kev12345 kev12345 is offline
Trim Level: Sport 4x4
Rep:14
kev12345 is on a distinguished road
Your probably spending around $40,000 anyway, so why settle with an inferior transmission to save a measly 2 or 3 g's (I'm assuming).
Old 09-02-2013, 05:14 PM
Gantman's Avatar
Rep:974
Aw come on guys, plenty of guys with well over 70000 miles on here getting no troubles from the 545/65RFE. The only ones really having problems are the guys consistently doing burnouts and the boosted Hemis. Normal everyday usage is perfectly fine. But if I could have waited, Most definitely I would have wanted the ZF-8speed. But why add another bill when I'm all paid off with my 2012, Clear title in hand? I will wait for either the EcoDiesel to get its quirks out or completely go off the reservation and try out the rumored 5.0L Cummins in a Titan. Sorry for the thread jack gents.
