Old 03-20-2014, 02:00 PM
Doc M's Avatar
Doc M Doc M is offline
Vehicle: 2012 Ram
Color: True Blue
Doc M is on a distinguished road
Switch control with Evic and Uconnect 5604 6097 AD
Old 03-20-2014, 11:55 PM
mxracer72584's Avatar
mxracer72584 mxracer72584 is offline
Vehicle: 2012 Ram
Color: Blackberry pearl
mxracer72584 is on a distinguished road
I have had great luck on car-part.com, searches salvage yards all across the nation, most ship items at reasonable rates. takes some calling around to find one with your mileage if it is not listed, if you want to match them up.
Old 04-03-2014, 12:50 PM
baf6 baf6 is offline
Vehicle: 2012 Ram 1500
baf6 is on a distinguished road
just picked up a 2012 cluster on ebay for cheap, and just noticed that it came from a 2wd 1500...i don't think this is an issue, but can someone confirm that it will work on my 4wd?
also, is 56046097AD definitely the right switch for trucks that have cruise settings on the wheel on the right side, and step/reset and uConnect buttons on the left? took a look at my coworkers truck, but he has up/down on one side and right/left on the other side, with cruise on a separate stalk
Old 04-09-2014, 01:46 PM
got mine today, and popped it in on lunch...besides being off by 4K miles, my horn doesn't work, didn't try the wipers...i haven't put in the new EVIC switch (i need the one with uConnect controls), though i can't see that being the cause for the horn
the cluster is out of a 2012 as well
Old 04-12-2014, 08:43 PM
tinosram1500 tinosram1500 is offline
Vehicle: 2012 ram 1500
Trim Level: st with express
Color: red
tinosram1500 is on a distinguished road
Default adding evic success
hello ,new here on dodge forums.i've been reading on this forum for a while as a visitor .I have a 2012 ram 1500 st with the express package but no evic cluster.i already upgraded my radio to the touch screen rbz and had the dealer flash it for the uconnect to work.i have tried to install the new evic cluster but having the same issues with the horn not working.the cluster I got is from a 2011 ram 1500 with almost identical mileage as mine.where can I get the wiring diagram for the horn.i' ve been reading about splicing and cutting some wires but I need a picture.also I will be installing the steering wheel switch to control the evic and uconnect from steering wheel.any help appreciated.my new cluster is within 150 miles from my original and will be installed permanently into my truck.can I do all the upgrades after.
Old 04-14-2014, 06:46 PM
CREWCAB R-T's Avatar
CREWCAB R-T CREWCAB R-T is offline
Vehicle: 2012 RAM CREW CAB 1500
Trim Level: EXPRESS
Color: DARK CHERRY RED
CREWCAB R-T is on a distinguished road
I completed my install following the info posted here... look at page 5, I think the instructions are there, JHOUSE is the author of the instruction post. I apologize as I can be of no help in resolving the issue with the non-working horn. My '12 cluster swap left everything working except for the Tire Pressure readings. Have you guys checked the wiring to make sure it stayed connected when re-installing your airbag/horn assembly?
Old 04-14-2014, 06:55 PM
Trim Level: EXPRESS
Those of you that have done this swap, how much were you charged to have your truck 'flashed' to work with your EVIC??? I'm having it done today and I had the service manager telling me it could be anywhere from $60-$120... I told him that I felt that a simple 'flash' for tire pressure monitoring shouldn't have to be that expensive ($120) but, then again, I don't know what some of you may have been charged. I installed everything myself, only having them 'flash' my truck. What did you pay?
Old 04-15-2014, 07:43 PM
padillavp padillavp is offline
Color: mineral gray
Rep:19
padillavp is on a distinguished road
Great job and that sounds really easy to do im looking foward to doing the same swap on my 12 express
Old 04-16-2014, 12:14 AM
ric221's Avatar
ric221 ric221 is offline
Vehicle: 2010 dodge ram
Color: PR4 Flame Red
ric221 is on a distinguished road
have any of you guys done this swap on a 10? and is the process the same as the 12?
Old 04-19-2014, 12:13 PM
Color: mineral gray
Rep:19
Hello im interested in swapping my cluster out for one with evic center does anyone know where i can find one with mileage close to what my truck has im currently at 13,300 on a 2012 ram 1500 any help would be much appreiated thanks.
